Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 22, 2025, 01:08:49 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 46LA-S Carb
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OS 46LA-S Carb (Read 973 times)
Jay Wood
AMA Member
Trade Count:
0
New Pilot
OS 46LA-S Carb
on:
July 12, 2009, 02:38:57 PM »
I was wondering if anybody knows if the venturi carb on the OS .46 LA-S will fit the OS .46AX. I have a AX I'd like to convert to CL. I've contacted OS tech support today(Sunday) and probably will get a response sometime this week but I thought I'd ask you folks first.
Jay
Logged
phil c
21 supporter
Trade Count:
0
Admiral
Re: OS 46LA-S Carb
Reply #1 on:
July 12, 2009, 04:46:11 PM »
The AX uses a large, two needle carb. The LA uses a much smaller, airbleed carb. I'd be amazed if the two interchange. The AX carb mount is at least 2mm larger than the LA.
Logged
Jay Wood
AMA Member
Trade Count:
0
New Pilot
Re: OS 46LA-S Carb
Reply #2 on:
July 12, 2009, 05:40:42 PM »
Thanks Phil,
I guess the AX is headed for eBay
Jay
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: OS 46LA-S Carb
Reply #3 on:
July 13, 2009, 08:26:32 AM »
Contact Jim Lee at Lees Machine here in the vendors corner. Or any of the fine vendors we have on this site. DOC Holliday
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Jay Wood
AMA Member
Trade Count:
0
New Pilot
Re: OS 46LA-S Carb
Reply #4 on:
July 13, 2009, 03:19:44 PM »
Thanks for the referal John. Jim had a affordable solution in about 5 minutes.
Jay
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 46LA-S Carb
