  • June 21, 2025, 11:54:57 PM
Author Topic: Tygon fuel line?  (Read 2018 times)
Offline frank mccune
Tygon fuel line?
« on: January 14, 2015, 06:38:20 AM »
     Hi All:
     Is this line suitable for glow fuel use?  Is it suitable for Diesel use?
        Tia,
        Frank
Offline dennis lipsett
Re: Tygon fuel line?
« Reply #1 on: January 14, 2015, 10:52:56 AM »
     Hi All:
        Tia,
        Frank
It is really not glow suitable but is diesel/gas friendly.
Offline Phil Krankowski
« Reply #2 on: January 14, 2015, 08:08:52 PM »
It is meant for petroleum based fuels.  I have used it with glow fuel and it hardens up some (it is pretty hard to begin with compared to silicone).  It was installed over a year ago and it still is fine, although I really flew on it a couple months.
Phil
Offline GregArdill
« Reply #3 on: January 15, 2015, 04:21:14 AM »
Frank,
It's perfect for diesel use.
It's available in a wide range of sizes, so be sure you use one appropriate for your intended use. I use a very small thin walled size which works perfectly with TR shutoffs.
I get mine from the local mower shop, as it's used on whipper-snippers (maybe brushcutters in the US).
« Reply #4 on: January 22, 2015, 07:11:45 PM »
  I think silicone is a lot better for glow fuel, its much more flexible and resist heat better. I used Tygon in my Lotus Esprit and it was OK for that, but it gets stiff over time. Then it cracks and dumps raw gasoline on the coil and distributor.
« Reply #5 on: January 22, 2015, 09:09:29 PM »
I use it in most of my ignition planes as I run fuel most of the time but also run gasoline or Coleman stove fuel part of the time. I have not had much trouble unless I remove it after a year or so as it gets very stiff and hard to put back on the fittings at the tank and spray bar.
Offline GregArdill
« Reply #6 on: January 22, 2015, 10:09:20 PM »
Real Tygon brand Tygon works perfectly well in my whipper snipper where it's immersed in fuel for the fuel line.
Maybe inferior brands will harden and split over time.
Greg
« Reply #7 on: January 24, 2015, 10:06:43 PM »
These guy must be using yellow vinyl, I've had tygon on my Foxberg for years with no problems.
