  • July 14, 2025, 12:59:41 AM
Author Topic: TT .25GP CL Conversion Parts?  (Read 3776 times)
George Hostler
« on: April 19, 2015, 07:16:57 PM »
In an old thread, http://stunthanger.com/smf/index.php/topic,7992.0.html of 7 years ago describes available CL conversion parts for Thunder Tiger .25GP R/C engine.
That was a while back. I've got an NOS .25GP R/C. Does anyone know where I can get a venturi and NVA for it?
Re: TT .25GP CL Conversion Parts?
« Reply #1 on: April 19, 2015, 08:12:27 PM »
George, I bought a TT 25 Pro( ball bearing version) from Mark Boesen a few years ago for my Shoestring. It has a sprinkler type venturi with a Supertigre NV. You might ask him where he got the CL parts. I have to choke the venturi, but if I do that and run 20% nitro, it runs great.
Rusty
George Hostler
« Reply #2 on: April 19, 2015, 11:53:22 PM »
Perhaps I should clarify. This is the old plain bearing .25GP made in the 1990's, not the more recent GP-25. I don't know how similar or dissimilar these two are.
Offline Geoff Goodworth
« Reply #3 on: April 20, 2015, 02:04:41 AM »
George, I have two TT GP25s NIB. Mine were bought as CL engines so the NVA is factory stock. The pinch bolt hole is 4mm so an ST NVA fits.
The factory venturi is too big—I have one in a GP 40 and it may be a bit big there, I don't know yet.
The venturi was made by Scott Reese and is 0.136" ID.
I have one running in a Ringmaster and the engine seems quite happy.
George Hostler
« Reply #4 on: April 20, 2015, 07:33:18 AM »
The engine I have is the earlier Magnum .25GP by TT. Width across pinch bolt is 13mm. Engine looks similar in appearance to yours, I don't know the differences if there are any.
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: April 20, 2015, 08:23:09 AM »
Funny, Tony Drago and i were just checking those this weekend. They are the same carb, or venturi or whatever you're using. Also, i want to check something today, i might have a quick cheap solution for you George!
« Reply #6 on: April 20, 2015, 06:04:39 PM »
George, I measured the boss on mine and measured 13.5mm (~17/32"). A GP 40 was the same.
The pinch bolt is 4mm, so the hole is a good fit for an ST NVA. I used ST 46 NVAs on some of mine but to centre the hole in the boss required brass washers both sides.
I measured a Brodak 40 NVA and I believe that it is ideal—if/when you can get them.
« Reply #7 on: April 27, 2015, 02:26:24 PM »
I just purchased a new TT Pro 25 Ball Bearing RC and, I am looking for CL conversion parts also. If anyone can help me out please let me know.
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: April 29, 2015, 08:37:20 AM »
Here's a TT25 PRO with a conversion set froM Bill Bischoff. It's meant for the Magnum 15 for racing, but works well on this engine for stunt.
Online Steve Helmick
« Reply #9 on: April 29, 2015, 07:09:07 PM »
Either Randy Smith or Leonard Neumann will be able to fix you up with both venturi and NV Assy. I am a big fan of Randy's Aero Products NV Assy...as you will be! Leonard has them, generally, as well as Randy, of course.  y1 Steve
« Reply #10 on: April 29, 2015, 09:20:31 PM »
Hmmm, mine is different. Same engine but the Supertigre spraybar goes through the hole where the retaining bolt is on yours and feeds a 3 hole sprinkler venturi a lot like a Tee Dee. Mine needs choking down. I wonder if I could JB weld a ring of short brass tube in the venturi to neck it down a bit. Maybe someone has tried that and can tell me if it's a reasonable idea.
Rusty
Offline Dane Martin
  • heli pilot BHOR
« Reply #11 on: April 29, 2015, 11:03:57 PM »
What size is your venturi, rusty? This one is a .250
« Reply #12 on: April 30, 2015, 01:32:00 AM »
The venturi in my TT GP25 with the ST-style NVA through the pinch bolt hole is 0.136".
With no spreay bar restricting the venturi throat, you need to forget all your 'conventional wisdom' on venturi ID.
Offline YakNine
« Reply #13 on: June 01, 2015, 09:10:33 AM »
The RSM Magnum .15 fits but needs 2 o-rings I think I used an RSM ST nv for an la46 and it runs good on an ARF streak.T.J.
AMA 85135        GSCB
« Reply #14 on: June 01, 2015, 10:16:33 AM »
Got a NEW T T Venturie the other day . Teeny Hole . UNFORTUNATELY I needed TWO ! SIX WEEKS WAIT ?? WHATINTHEFK .
Anyway , have the ' part no , PN1081”
' the ' deck hight ' is larger than the MaGNUM ! SO NEEDS A SPACER .
The MVVS D7 , ST C 35 & Magnum 25 *& 40 match . The TT 25 is about 1/8 plus at the O ring , as it were .But Diameter matches . For my GP 25 Magnums .
or to clear the mud , the TT intake fitted to a Magnum etc requires a slice of rubber tube , 1 / 8 in odd , as an O ring . so I figure .
« Last Edit: June 02, 2015, 07:12:31 AM by Matt Spencer »
