  • June 21, 2025, 06:25:12 PM
Author Topic: Fox 35 Stunt mounting pattern equivalents  (Read 1085 times)
Offline Sport Pilot
« on: May 26, 2013, 06:40:40 AM »
Hi gents.
Dos someone know if the Fox 35 mounting pattern is equivalent to one of these engines?
ST C 35, ST G 21/35, OS 35 S and 35 III ?
Thanks by your help
Sport Pilot  H^^
Re: Fox 35 Stunt mounting pattern equivalents
« Reply #1 on: May 28, 2013, 12:58:11 AM »
The OS 35-S is the only one of those that's even close. The ST engines are a good bit wider.
Offline Geoff Goodworth
« Reply #2 on: May 28, 2013, 06:30:35 PM »
I understand that the OS 35-S is the same external dimensions as a Brodak 40 and I've just fitted a B40 where a Fox 35 once lived. The bearer spacing is OK but the distance from the prop driver to the back of the engine is 0.30" greater on the B40 and the mounting bolts are further apart.
Lucky for me, I had space behind the Fox so the prop is in the same place with the B40 and the mounting bolts straddle the rear bolts of the Fox with plenty of clearance.
Offline Sport Pilot
« Reply #3 on: May 31, 2013, 08:03:08 PM »
Thank you guys  H^^
