  • June 22, 2025, 01:56:32 PM
Author Topic: Transistor spark ignition modules  (Read 771 times)
« on: April 12, 2009, 05:53:15 PM »
Since returning from VSC, I have made another run of these nifty little devices. If anyone is looking for these, contact me and I will se what I can do.
Also working on one that will shut the coil power off if the engine stops with the points closed. Hope to get the prototype out to my test engineer soon. Works great on the bench. just need engine starting tested.
Don
