  • June 16, 2025, 11:12:10 AM
Author Topic: fp.35 without a thust washer  (Read 1578 times)
« on: August 29, 2016, 06:32:51 PM »
Allen's thread reminded me of a question I have.
He called it a space washer, so I don't know which term is correct. I bolted an fp.35 onto my Twister and realized the thrust washer was missing. Probably borrowed for another engine and forgot. I would not use an electric starter without it, and the crank has very little float fore and aft float. Is there any reason it could damage the engine? All I can think of is if maybe the crank floats whenever it burps or shuts off, or when I'm flipping it to crank, causing contact between the drive pin and backplate. I've flown about 18 flights and plan to replace it before the next time, but I'm curious about it.
Rusty
Offline mike londke
Re: fp.35 without a thust washer
« Reply #1 on: August 29, 2016, 07:09:19 PM »
I wouldn't. We had a guy do that with an LA 15 He hit it with an electric starter and galled up the case and bushing pretty bad. Its there for a reason.
« Reply #2 on: August 29, 2016, 09:22:12 PM »
Clankety Clankety Clank , flicking the Iron FP 40 ive fitted to the MC 72 . Surprise Surprise , appears to be no thrust washer .
Though the cranks got say 3/4 or at least 1/2 mm freeplay , fore & aft . Another CHORE ; Find One . Runs ok though .
« Reply #3 on: August 29, 2016, 10:04:40 PM »
Yes it can and will damage it, first you are pushing aluminum to aluminum, that can gall the front od the case and the drive washer
Second it is possible you can contact the backplate with the crank pin / rod
« Reply #4 on: August 29, 2016, 11:03:33 PM »
Okay then, I'll put one on it before cranking it again.
Rusty
« Reply #5 on: August 30, 2016, 07:31:54 PM »
I'd expect one for a .40/.46LA would be fine, if that helps. Early in the LA saga, they said the LA crank was okay to replace the FP crank. That from Leonard Neuman. For ST .35C's, I always replaced the stock thrust washer with a thicker one...after having to remove the (now conical) stock thrust washer after a typical combat match. Maybe you could scout up a Gr.8 washer at the hardware store that you could make work without too much modification. Balance won't be a problem, due to the small revolving radius involved.  H^^ Steve
