Engine basics => Engine set up tips => Topic started by: Randy Powell on July 23, 2007, 01:08:03 PM
Title: Tom Lay OS46VF question
Post by: Randy Powell on July 23, 2007, 01:08:03 PM
I haven't run this engine in awhile. Can someone tell me a good starting pipe length for a Tom Lay set up OS46VF? I can't remember. The pipe is an Eather "60" sized pipe. I've ran the combination before, but it's been awhile.
Title: Re: Tom Lay OS46VF question
Post by: Mark Scarborough on July 23, 2007, 01:25:42 PM
Randy, obviously, start with the "correct " length,, sheesh even I know that,,  LL~ LL~ LL~ LL~
Post by: Larry Wong on July 23, 2007, 01:53:36 PM
Hi Randy I don't know if it helps but I run my Tom Lay 40 VF at 18.5" and launch about 10800K
Post by: Randy Powell on July 23, 2007, 02:58:00 PM
Mark,
 na#
Larry,
Not the same. I run my OS40VF (box stock) at 18.5" on a Aeropipes "51" pipe with launch rpm at around 10,800 and it's great. The Tom Lay 46VF is a different animal. I think the pipe lenght I used before was about 17.5" with a launch rpm of about 9800, but I'm not sure. That's why I asked.
Post by: Chris McMillin on July 23, 2007, 03:48:37 PM
Randy,
Start long and move it in. It won't get hot that way. 17.5 is what I used to run on the OS 40, OS 46 and T&L 6.5. Interestingly.
I use about 18.25 on the PA 61, but it is so dependent on the engine's other factors, so I'd go long and creep up on it.
Chris...
Post by: James Lee on July 24, 2007, 01:52:23 PM
I don't run a pipe, but my comment is to use a logbook with pertinent info so it doesn't get lost....    I can't remember yesterday, so GOTTA have some notes   y1  HB~>
Later
Jim
Post by: Randy Powell on July 29, 2007, 12:12:23 AM
James,
I usually do that, but in this case, the plane only got about 5 flights on it before I gave it up for a loss. Great hanger queen, but that was about it. But the engine ran great.
