  • July 13, 2025, 04:07:42 AM
Author Topic: Tom Lay Os max 35s  (Read 1536 times)
Offline Randy.Birt
Tom Lay Os max 35s
« on: November 01, 2019, 07:34:25 AM »
Can anyone tell me what the difference between a Tom Lay 35s and a stock one is? What was done to these engine to make them better?
Thanks yall
Re: Tom Lay Os max 35s
« Reply #1 on: November 01, 2019, 09:57:38 AM »
Tom never disclosed his re-work procedure.  Suffice to say, his re-work resulted in better running and longer engine life.
Offline Chris Sarnowski
« Reply #2 on: November 01, 2019, 10:26:51 AM »
Check this thread which talks about what things Big Art and Randy Smith would do to them.
Also has info on the weak points of the engine.
https://stunthanger.com/smf/engine-set-up-tips/art-adamisin's-os-max-s-35s/msg522121/#msg522121
« Reply #3 on: November 01, 2019, 09:22:13 PM »
   I have several T&L .35Ss but have never dissected them. From conversations with Tom and those that knew him, Tom just mostly hand fitted engines for minimum clearances and best fits, a time consuming process. He had a technique for heat treating pistons to make them last longer and in that process he was able to make the cylinders and pistons truly round for best fit. I think he bushed the rods and hardened those also. I don't think he changed any timing, as there was no need to.  This is much the same with the work he did on Super Tiger engines. Mix and match parts for best fit, true cylinders and hardened rings. Make sure all bearings are the best and fit well.  Tom's engines ran well, make great power and last a long time if cared for and fed a proper diet. Two of mine may end up in a Sheeks Mosquito.
