Hello all.
After "cooking the piston" in my OS, it has gained apreciable compression, not great but usable.
Ill try it flying as soon as I have a suitable plane for it. Thanks all for your help!!!!!
Regards from Spain.
Hi Manuel
One thing you need to check is the piston wrist pin holes, They are very very bad to wear out quickly on these engines, if yours are sloppy and worn, it will not matter what you do with knurling ( which tends kill the piston pin holes) or cooking.
I have tried cooking many of them with never a success. The 35S pistons have almost no growth in them new, and you will find most all of them will not grow after being run for a while, you may get a skin baked on them from residue, but I don't think you will have much luck with the baking trick on an OS 35S
As others have said here ,The best thing you could do is try to find another, or get a lapped ne w set from Brian Gardner.
The only other real option is to get someone to chrome the sleeve for you and fit the piston to it
