  • June 20, 2025, 12:46:07 AM
Author Topic: Thunderbolt 4-cycle glowplugs  (Read 1351 times)
« on: June 24, 2009, 09:32:26 PM »
Somebody recently mentioned that the T-bolt 4-cycle glowplugs were no longer available, & not shown on the Hobby People website anymore. Typically, I don't recall who said that...but it's not so!  ??? NOT SO! TRUE, it says they're out of stock, but you can backorder them...which works very well, OBTW. Hobby People runs a tight ship, from my experience.   http://www.hobbypeople.net/gallery/115480.asp
I don't use the T-Bolt 4-S in every engine, but have some engines that I do use them in. I wouldn't use one in a 4-cycle, opting for the OS or YS plugs (that are said to all made by OS and effectively identical except for markings). But I'd put one in an Evo .36 in a heartbeat. I've always run one in my 2Star .60bb, and have used one in a ST G.51, with fine results. There is no 'idle bar', and they don't have an extended 'nose' like the OS 4 stroke plug, making them a pretty wonderful stunt plug....  H^^ Steve
Re: Thunderbolt 4-cycle glowplugs
« Reply #1 on: June 24, 2009, 09:44:51 PM »
Hi Steve
I hate to have to tell you this but the plug you have listed is not the old 4 Cycle T Bolt plug, It is the new plug they replaced it with, Th4e High Performance Big Bore 2 and 4 cycle plug. The 4 stroke plugs are gone.
The new plug works better anyway
I have stocked them before Global even started selling them, and they work very well in many motors
« Reply #2 on: June 27, 2009, 08:32:12 PM »
Randy...In what way are these new plugs different? Do they have the extended nose like an OS "F" or an idle bar?
Do they look different in some distinguishing way? Thanks for correcting me, anyway.  :-[ Steve
« Reply #3 on: June 28, 2009, 08:17:51 PM »
The new Big bore plugs have a differant formula element, They are 30% rhodium instead of the 20% of the 4 cycle. The body has  2 cut machined marks around the middle body of the BIG Bore plug. The 4 cycle had no groove
