Engine basics => Engine set up tips => Topic started by: Bootlegger on August 08, 2017, 06:45:09 AM
Guy's what is a good prop, nitro content, oil content and percentages, and any other info on running in one of these engines
Thanks... #^
I used the search function on here and got 33 replies
Why rehash it all over again
On the other hand, the 33 replies do not in any way answer the question...I read all 33 of them from Using "Thunder Tiger 36" as the search
I tried several other search methods and still came up with no good info
I know the answer about various TT 36 set up are here cuz I have read them over the years
BUT I think it is buried inside a Nobler ARF or some similar thread
Sorry Gil I do not have the answer but I know Randy Smith does for sure
and If I know Randy he is gonna have advice like Nitro as needed per local conditions...meaning 5 to 15% depending on air temp
I think the TT 36 is old skool so probably in the 22~28% oil region.... never had one so basically lower oil if ABC/ AAC and higher if Iron liner
Prop range is goona be subjective based on the plane and I have no clue--- but I bet the same range as and Evo .36 or OS 40
Thanks fellow's, I appreciate the help...
I bought a TT.36 used from one of the forum members, this was their suggestion:
George,
I ran Thunder Tiger 11x4.5 props and APC 11/4 an 5 props. I have never used 15%nitro on any of my C/L engines as it really isn't necessary where I live. makes the engine over accelerate and the fuel economy goes out the window. Use 5% in normal weather and 10% when reaching the 90's at 11K it isn't a bad run but set the engine to get the speed range that you want. Changing venturis is the easiest way to do this.
If it helps, both Bruce Hunt and John Thompson (both fly Expert) tried to make a standard TT .36 work in an ex-Don McClave "Blackbird", and failed. And I think both are pretty good engine guys. Eventually, JT saved up his nickles and sent it off to Randy Smith. I don't recall if it got modified OEM parts or if it got the full tilt Aero Tiger treatment. Stock, they make a pretty good Beginner's Navy Carrier engine, according to Mike Potter. H^^ Steve
Hmmmm....
That's odd! Steve Moon used one for quite a while in a Geiseke Nobler for VSC, very successfully. I also had one in a G. Nobler and it ran reasonably well. Both Steve and I are also Expert level fliers and while it did take some minor set-up to achieve there wasn't any major mods required.
Mine had a completely stock engine with a .265 venturii and ST Needle Valve assembly. I used a Phelps style 10.5- 4.25 prop and because I live in Tucson, 15% nitro with 20% oil (half castor and half Klotz).
It gave very good runs. It did require a careful initial needle setting for the day but once achieved it was quite stable and ran a very strong wet 2 with a slight increase at the tops of maneuvers. On hot afternoons the nitro was increased to about 18%.
I eventually replaced it with an Aerotiger because I had one. While the Aerotiger was easier handling with a much broader sweet spot, it really didn't work any better than the stock engine when properly adjusted.
One thing that was key to setup for both the stock engine and the Aerotiger was the proper amount of backpressure on the tongue muffler. Many holes were drilled and tapped for 4-40 screws and screws were added to holes until the proper backpressure was attained. Most of the people I knew at the time were tuning Aerotigers that way and it worked also on the stock engines with the setup mentioned.
No it wasn't "choking" the engine just controlling it. The engine was still very powerful and would fly a larger airplane if necessary! I don't remember the precise number of holes or screws but someone around probably does! I'm pretty sure that I picked it up from Bill Werwage at VSC many years ago. I seem to have some recollection of Ted Fancher being involved with one there also! (Aerotiger).
Thanks... #^
Hi I sent you an email reply to your questions : Try a Cyclone 11 x 4.5 , TF 11 x 4 APC 11.5 x 4.5 , 20- 22% oil mostly synthetic , Merlin hot big bore plug, wet rich 2 stroke, or some get a 4/2 hi RPM break around 10,500 RPMs
DO NOT use all castor , this is NOT an old school engine, its a ABN dual ball bearing Loop Charged engine
DO NOT stop up the tongue or tube mufflers with bunches of screws, The reason Bob and Billy did this was they had venturies that had been opened up 7 step larger than needed
Use a true venturi with a # 17 or 18 drill size, this will be the same as a .270 to .280 restrictor venturi , if you must drill thu and ruin the case to use a needle thru the restrictor venturi, take care, the sides are not round and it will leak, the carb hold down/Needle valve hole at the back will need to be sealed well so it does not leak
Hmmmmm. I wonder why mine worked so well. Guess there's more than one way to skin a cat! Or set up an engine!
They have large power and a large envelope they will run in, But I have had people burn them up putting many screws and choking the exhaust down , When I removed the 8 step too large venturi from Billy's engine, the screws needed to come out, result , better run, more power less heat, , the relationship between the intake and exhaust are tied to each other, open the exhaust and the intake "acts" bigger, close it down and the intake "acts" smaller , helps if you are running too large a venturi but is not optimal. You hit on a combo that worked , however that does not negate the things I wrote about how to set up the engine. I would suspect you would not need near 15 to 18% nitro with the screws removed. I have been in Tucson many times with guys running Aero Tigers with 5% fuel and making huge power, as you say different ways to do things
Regards
