On the LA 46, trying to get a Fox 35 style run is not really beneficial, nor is it desirable IMHO.
The LA 46 runs great right out of the box. Its light, reliable, reasonable on fuel and inexpensive. Just what you want when there is a chance you will find the ground in an unfriendly angle...
Latest news on setup,, take it out of the box, put a .272, - .275 venturi on it, with a ST or PA needle assemble THROUGH the venturi, in other words, dont use the remote needle ( this isnt a deal breaker, but if you dont use a through the venturi needle of the same size as the ST or PA needle, then you need to recalculate the venturi size) Use an APC 12.25 x 3.75 prop, 10% nitro fuel with 22 % oil, equal parts castor and synth. I would reccomend a 5 oz Uniflow tank with muffler pressure, ( it makes certain things more consistant) Needle it for 9600 to 9800 depending upon your airframe and tank setup. release it and enjoy.
Break in would be several tanks on the ground, but you will find the run " sweetens up" as it gets closer to a gallon of fuel through it
I have not ever needed to add shims, remove shims, alter ports or timing.
the only thing I noted was that one of mine needed a bit more castor to be happy. IOW it would pick up rpm noticable when I flew the square eights, and then stay at that rpm instead of coming back down. a couple ounces more castor added to the gal of fuel solved that problem.
