  • July 26, 2025, 09:34:39 PM
Author Topic: thunder tiger 36 cylinder heads  (Read 2659 times)
Offline Bootlegger
« on: August 23, 2017, 09:19:29 AM »
  I did the search, and still don't have the info I need.  Is the square head actualay a rectangle shape?  I have a couple of these engines and have read that the sq head is the one to have, so is this the sq head?
   In advance THANKS...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: thunder tiger 36 cylinder heads
« Reply #1 on: August 23, 2017, 09:45:56 PM »
OOps , Id think the SQUARE may be the ' H ' helicopter head , and the ROUND the Aero , which is Square - Rounded off . Obviously the Aero would be more conveiniant . Unless you had a square cowl .
oops . The R E is a 120  >:( THIS is the 36 !
Tho this could get Confusing .
 LL~ actually this is a CAR one , with the no good funny crankshaft . So Hardly relevant to ' our ' conversation .  ;D
« Last Edit: September 03, 2017, 05:34:21 AM by Matt Spencer »
Offline Bootlegger
« Reply #2 on: August 29, 2017, 08:54:54 AM »
   Thanks Matt, the ones that I have have the head like the rear exhaust, so I am gonna say that is the sq head version, now who has some good suggestions for good stunt runs, using the hi-rpm low pitch run...
Gil Causey
AMA# 6964
« Reply #3 on: August 29, 2017, 07:24:42 PM »
Some one  told your  wrong, they are confused  there  is  NO  round head Thunder Tiger 36,  maybe they  were thinking about a  Magnum 36
The  TT can be made to run very well  I have done  about 900 of them, many of them are flying ay most contest you see
Use true venturi  with # 17 drill size, 1 or 2 head shims, NO MORE,  a prop like a 11 x 4.5  Cyclone,  Top Flight  11 x 4  , aPC  11 x 4/5   etc,  10 nitro 22 percent  oil, mostly synthetic, and they will run either  hi RPM  4/2  or  wet 2
Offline Bootlegger
« Reply #4 on: August 30, 2017, 09:00:44 AM »
  Thanks fellows, the T T 36 that I have is the 36 Pro, so I will work with that using the suggestions from Randy Smith, again every one thanks..
Gil Causey
AMA# 6964
Offline Bootlegger
« Reply #5 on: August 30, 2017, 09:14:34 AM »
  Randy, what thickness are the stock head shims, and where can I get some of them?
Gil Causey
AMA# 6964
« Reply #6 on: August 30, 2017, 05:30:34 PM »
I have them, they  come with  2 head shims, 1- aluminum .012   and  1- Copper  I think is  .003 , also in the pack is  rear cover  gasket  and  1-  crankshaft steel spacer, they are  6.95  per pack
Offline Mike Bufkin
« Reply #7 on: August 31, 2017, 04:49:46 AM »
Randy,
Is the TT Pro 36 the same engine the Aerotiger is made from ?
If so,
do you still do them when you can get an engine ?
« Reply #8 on: August 31, 2017, 11:01:55 AM »
Randy,
If so,
hI MIKE
AERO  TIGERS   were  , to start made from magnum 36 engines that were made in Taiwan ,  then after they started to make Magnums in China, Since they have all been made from Thunder Tiger  36s,  So you have the same motor, badge as Magnums and Thunder Tiger, Thunder Tiger  made ALL Magnum engines up until the point that they moved them to China
 I am working on getting another  run of  Aluminum Chromed  sleeves, I have the other  parts here, I will let you know  how and when  If I get them in
« Last Edit: September 03, 2017, 04:51:37 PM by RandySmith »
Offline Mike Bufkin
« Reply #9 on: September 03, 2017, 05:03:44 AM »
Well,
Iwas bidding on one on ebay that went for $117.00
Ridiculous !!!!
« Reply #10 on: September 03, 2017, 05:22:34 AM »
You Can Have Mine , for That .  ;D
THINGS seem to come in batches , over a few weeks , like on R C forum & ebay . Been a few on Ea a month back . And FSR 45 Royals a year back .
Comes a point when theyre all ' spoken for ' and the price jumps . From 20 Bucks .  >:(
HELICOPTER ones as often in the TT 36 . cheapest worthwhile looked to be $ 60 plus .
A lot of ABN stuff is shot , tho if your relinering it , thatd be ok if thats all that was ?????????????????????? IF IT WAS DIRT CHEAP .
a certain 50 FS Heli in ' MINT ' condition appears to be BRASS exposed from A to B in the bore .
Caveat Emptor
as Julias Ceaser said .  :-X
