Engine basics => Engine set up tips => Topic started by: jim gilmore on October 10, 2009, 04:57:11 AM
Title: thunder tiger .10 muffler question.
Post by: jim gilmore on October 10, 2009, 04:57:11 AM
I got a thunder tiger .10 and wish to change the screw type bolts bthat hold the muffler on to a socket head type?  What is the correct socket head type  Also what is the correct size for the engine  mount on a .10?
Title: Re: thunder tiger .10 muffler question.
Post by: Alan Hahn on October 10, 2009, 09:54:49 AM
Jim,
I am not sure I can answer your question, but I am sure the muffler bolts are metric. The best local spot to find some would be a local hobby shop (if you have one) since most RC cars now are metric and they will usually have a supply. The only issue will be if they have some that are long enough.
I think I still used 4/40 bolts on the mounting setup with planes like the Ringmaster Jr, and Sig Acromaster----basically that's what I have. 2-56 might be ok. I know I have some 2-56 blind nuts. Now that I think about it, I probably would use 2-56 simply because the maple wood on your 1/2a Pathfinder might be too narrow for 4-40 size bolts. Might want to consider using some 2-56 washers under the bolt head to spread the load on the engine lugs.
Post by: jim gilmore on October 10, 2009, 10:54:02 AM
Well i think i used  4-40 but the drilled holes just seem like they could be 1 size bigger. I think it was maybev1/8 th inch but I'm not sure.
Post by: Alan Hahn on October 10, 2009, 12:43:21 PM
Well I went and grabbed my FP10, which I think is the same as the TT10. The muffler bolts are 2.5mm diameter (0.098") and ~23mm long. I think the thread is 0.5 mm pitch (1 turn=1/2 mm).
I see from my metric bolt chart that a standard bolt is a 2.5mm x 0.45mm pitch. That is probably it. The closest domestic bolt would be a 3-56, pretty darn close actually--if you can find one, and that is at least an inch long. I bet it would work fine.
Post by: john e. holliday on October 18, 2009, 12:37:40 PM
Again I say if you have an engine that needs socket bolts/machine screws.  Take said engine or muffler to your local Ace Hardware and start in the bolt and nut department.  Have fun,  DOC Holliday
Post by: jim gilmore on October 18, 2009, 01:52:18 PM
Hello Alan, Not trying to know any holes here... I'm in NYC but my chance of getting around is MOM dependent. She has good days I get a quick walk in the local area and she has bad days. I don't get out and spend the day trying to keep her calm. about 2-3 months ago I made it to the local ace hardware. That was a train trip to columbus ciricle and then walked 2 miles uptown to about 90 th street. And they weren't like MY local ace hardware in ca. about 50% MORE EXPENSIVE AND DID NOT CARRY DRILLS BY THEIR NUMBERS.
