  • July 07, 2025, 04:09:54 PM
Author Topic: Older Enya carb question  (Read 3488 times)
Offline Terry Caron
« on: January 09, 2017, 11:46:55 AM »
Just received a used Enya .09 IV and, having no experience with r/c use or carb adjustments, I have a question:
The fuel inlet spigot is adjustable for intrusion into the barrel bore, so what happens to run characteristics when it's moved in or out?
Thanks.
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Brian Hampton
Re: Older Enya carb question
« Reply #1 on: January 09, 2017, 05:31:16 PM »
Moving it in or out alters the area of the venturi giving either more power/less fuel draw or less power/more fuel draw. Half way across is the factory setting.
« Reply #2 on: January 09, 2017, 05:35:29 PM »
Will you be using the throttle?  If so, and assuming that it has one, there's some art to setting up the air bleed so that it'll come out of idle cleanly.  Check back here if you need help.
If you're going to be using it as a big, complicated venturi, then you probably want to crank the air bleed in all the way.
Offline Terry Caron
« Reply #3 on: January 09, 2017, 05:41:08 PM »
Thanks, guys - thought so but wasn't sure.
It'll be used, at least for bench testing, 'til I get a venturi/NVA for it.
AMA 249824
NRA Life Member
« Reply #4 on: January 09, 2017, 07:01:21 PM »
As long as you're not changing the throttle position a carburetor just acts like a venturi.  So you should be good to go.  It must be an itty bitty little thing.
Offline Terry Caron
« Reply #5 on: January 09, 2017, 07:18:53 PM »
Bore is .150", spigot .155", Tim.
Looks a little oversize though.
(Pic as received - since cleaned!)
AMA 249824
NRA Life Member
Offline Chancey Chorney
« Reply #6 on: January 09, 2017, 07:55:08 PM »
Kind of funny with all this Enya .09 stuff going on. I just received my MK III about a month ago, and what a nice little engine it is. I could not find what I was looking for online, BUT, if it is anything like the III, you could just pull the carburetor and use it as is, as the carburetor is mounted inside the built in control line venturi.
« Reply #7 on: January 09, 2017, 07:59:33 PM »
Here is a snip from the Enya III article.
« Reply #8 on: January 09, 2017, 08:02:49 PM »
... as the carburetor is mounted inside the built in control line venturi.
It sounds like what they're calling the "restrictor" is what we'd call a "venturi" -- the thing would probably be to open for sport or stunt without a venturi, although if there are any vintage 09 speed events out there, leaving the intake as open as possible is probably the first thing you'd want to do.
Offline Terry Caron
« Reply #9 on: January 09, 2017, 08:06:18 PM »
You're right - I see that the carb mounts in a regular flared venturi, so just an NVA is needed to convert to c/l.
Thanks!
AMA 249824
NRA Life Member
Offline Terry Caron
« Reply #10 on: January 09, 2017, 08:12:18 PM »
My .19 4003 c/l engine has a removable steel insert to restrict the venturi further, Tim, and I suspect the .09 c/l would have one also.
AMA 249824
NRA Life Member
« Reply #11 on: January 09, 2017, 11:57:09 PM »
Huh.  My Enya 19-IV has a conventional aluminum venturi.  Do you happen to have a picture to post?  I'm curious as to what it looks like.
Offline Bill Johnson
« Reply #12 on: January 10, 2017, 08:44:52 AM »
The K&B Stallion had one also. Just a thin sheet metal insert formed to the venturi, with a split line and retained by the NVA.
Best Regards,
AMA 350715
Offline Terry Caron
« Reply #13 on: January 10, 2017, 09:09:20 AM »
Here ya go, Tim - appears to be spring steel.
AMA 249824
NRA Life Member
« Reply #14 on: January 10, 2017, 10:11:46 AM »
Thanks.
