  • May 27, 2024, 01:13:44 AM
Author Topic: Ugh!!! Castor oil...  (Read 1077 times)
Offline Bootlegger
« on: May 29, 2008, 10:29:36 AM »
  This is more or less for the engine "Guru's", isn't medicinal castor also good for engines?
   Seems that a few years ago Charley Melancon and I were talking about this and he commented that "If it's good for us it can't hurt an  engine".
  Charley is now deceased, so I can't go back and check with him although I wish I could... :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Ugh!!! Castor oil...
« Reply #1 on: May 29, 2008, 10:37:23 AM »
Yes medicinal Castor oil works really well it's more refined and more expensive than what we need. But it will work in a pinch. You can only get it in small containers around here. So it's really expensive to buy enought to mix for fuel.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Bootlegger
« Reply #2 on: May 29, 2008, 11:22:37 AM »
  Thanks for your reply Mike.  I picked up some at the local apothacary and had "sticker" shock.!
  Thank you for your help...
Gil Causey
AMA# 6964
« Reply #3 on: May 29, 2008, 12:44:36 PM »
HI Gil
YOu can use the drug store castor, but you will be much better off if you just buy a qt from SIG  or a nearby Hobby Shop, or a cart racing place may have some
Offline Bootlegger
« Reply #4 on: May 29, 2008, 01:30:08 PM »
   Thanks Randy. Never thought about the Cart Racing shops...
Gil Causey
AMA# 6964
Offline dankar
« Reply #5 on: May 29, 2008, 02:08:09 PM »
The market I work at has 6 oz. Bakers AA for $1.99 a bottle. Mixing smaller amounts isn't that expensive.
Cheerio,Dan
« Reply #6 on: June 01, 2008, 06:46:48 AM »
Clarence Lee of RCM fame wrote many years ago that medicinal castor was not degummed. Bakers AA was the thing to use in fuel. I buy it by the gallon from Sig.
Offline Brian Hampton
« Reply #7 on: June 01, 2008, 08:46:17 AM »
All castor is degummed as part of the initial manufacturing process. Medicinal castor has extra checks as a precaution to ensure there's no ricin poison left in it and may have some sugar added to make it more palatable...ugh. The early Merco instructions specifically warn against using medicinal castor.
AA castor, whether it be Bakers, Castrol M or whatever, just means it's only pressed castor and it's what's called Pale Pressed. #1 Imported (or Industrial castor) is a mixture of Pale Pressed and chemically extracted castor.
Offline 50+AirYears
« Reply #8 on: June 09, 2008, 08:53:06 PM »
In 18 months at Wheelus AFB from late 1965, most of the time we mixed our own 85/15 or 80/20 using medicinal castor from the base medical squadron and methyl alcohol provided from a 55 gallon drum provided by the paint shop.  A few squirts per gallon of Zippo lighter fluid seemed to aid starting.  Never had a problem, even though we flew next to a sandy salt farm.  I still am using a couple of the engines from that period, even though I recently changed the crankcases on most to the newer style to allow the use of mufflers.  They still have the same piston/cylinder combos.
Tony
Offline L0U CRANE
« Reply #9 on: June 10, 2008, 10:46:39 AM »
Speaking of the old days...
While in Omaha - early 1970's - I visited a (real) railroad repair shop. Noticed that they used Bakers AA Castor, from a big (gallon) red-label can, as release agent on the mold stub when they re-babbited wheel bearings. Asked where they got it. ...A neighborhood pharmacy around the corner from the yard entrance had a deal worked out with them... Their price was even a bit below Sig's at the time.
That's a third of a century ago. Sig still sells Bakers' AA, and no railyards are nearby. If I found one, it'd probably be under tighter security, now, too.
\BEST\LOU
