  • July 09, 2025, 10:38:41 AM
Author Topic: The Perils of NITRO Engines .  (Read 985 times)
« on: November 30, 2019, 07:19:01 PM »
With old not-recently run or even unused old-like new in-box motors, ALWAYS either tare the motor down or have it torn down and checked before use. Stuck wrist pins, stuck rings and rusty bearings are almost impossable to see and will shorten engine life. You may think you got away with it, and get a season or two before you notice a problem, but why do it? Parts are getting hard to find!! "
Courtesy of Eric V . Or Librerated Vis S. stunt ! .the above ! .
Thought Id follow my own advice & whip the backplate , Even tho the engine looked ' As New ' . Maybe run in, virtually no carbon discernable on piston .
Shoulda taken a picture before I got the C.R.C. & Heatgun on it . Only took six cans to get the wrist pin out. Or was it six goes .
Theres a 2.5 m.m. metric thread in the near end pad , so you can pull it from the wrist pin .  :P
Balsa Spacers so It can get going fwd. & back. Twisting .
Acetone & superglue can be used to glue in the pad . Tho not this time .
Re: The Perils of NITRO Engines .
« Reply #1 on: November 30, 2019, 07:35:26 PM »
Obviously the debri wouldnt have done the world of good , coming loose .
Typical if stored without a Tank of No Nitro fuel run thru , to clear the Nitro residue . Before long term storage .
Seems half the pre used engines you see suffer this .
And if Ball race the STEEL Bearings are often rotted / rusted . Tho the tracks being shiny are the last to go .
The debris comming off with the heat & pressure cycles , from running , will lead to tears .
And likely scour the Liner & shaft bearing . Result = scrap metal .
Clean with green 3M pads & elbow grease . . If youve a polishing wheel , dont let me stop you .
The aluminum seems to syurvive much better . But still can be badly pitted / eroded . Particularly from dampness .  :P
PLUS , the Conrod Top oil hole , was blocked with coagulated castor oil .  n~
The Datk stuff on the front of the flywheel is C R C gook & light surface oxidation . Will polish off . Left its debri .
