Both wrong. It's not a Combat .15 and not eastern made, But you are correct Ralph the Ringmaster was not made to go that fast.
Martin you are way off, this is a new engine.
The engine is a Brazillian CB .25. It swings that 10/5 prop at close to 11,000 RPM. On 58 ft. lines it tries to screw you into the ground. That little engine weighs in at 6.4 ozs. The tank is 3.5 ozs and it seems like an eternity before it runs dry.
Has an hour of run time and gets better every flight.
"Billy G"
