  • June 17, 2025, 12:45:00 AM
Author Topic: Supertigre 51 Parts  (Read 1133 times)
Supertigre 51 Parts
« on: May 03, 2015, 09:14:40 AM »
Does anyone know where I can the complete venturi, needle valve assembly and spray bar for a Supertigre 51 CL. Tower has all the listings, but they don't seem to carry the parts anymore.
Re: Supertigre 51 Parts
« Reply #1 on: May 03, 2015, 11:18:25 AM »
  Don't know about stock parts, but Jim lee could probably take care of you on the venturi, and so could Randy Smith. I'll bet Randy changed out the stock units for his when he did rework on them. Randy has needle valves that would work, and so does RSM.
« Reply #2 on: May 03, 2015, 11:33:03 AM »
Your right on all counts Dan. In fact, I currently have a number of motors with Randy. But this is something different, it's actually not for a ST51, I am trying to get stock, readily available parts for a special project.
« Reply #3 on: May 03, 2015, 01:44:15 PM »
  Look into the venturi for the ST.34 also then. I  just remembered they had a C/L version of that out for a while and I thonk the intake on it was similar to the .51.
