  • June 20, 2025, 10:28:47 PM
Author Topic: Tank Set-up Proper. Just want to be sure.  (Read 2565 times)
« on: December 06, 2015, 01:22:32 PM »
It's been quite a while since I placed an R/C tank in a model.
Now I'm placing an R/C tank in a CL model.
Scale application so no stunts and I will control the engine shut off using a servo on the carb. Just like R/C.
Anything wrong with this?
The copper is the vent.
Thanks in advance.
Charles
  • Gravitywell
Re: Tank Set-up Proper. Just want to be sure.
« Reply #1 on: December 06, 2015, 02:48:19 PM »
Hi Charles.  I'd switch the filler and pick-up tubes.  As it is, the pick-up tube will swing to the outboard side when in flight and may end up acquiring a hole by rubbing on the filler tube. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #2 on: December 06, 2015, 03:21:11 PM »
Hey! Hey!
Glenn to the rescue! What a guy!
Here's the change and thanks for the information.
It's appreciated!
Charles
  • Gravitywell
« Reply #3 on: December 06, 2015, 03:36:18 PM »
Perfect....now all you have to do is paint some red scallops on it! LL~ H^^
Glenn Reach
Westlock, Alberta
Offline Geoff Goodworth
« Reply #4 on: December 06, 2015, 03:56:46 PM »
Good call from Glenn. What fuel are you planning to use. Remember that nitro leaches brass—the zinc, I think—so it becomes brittle and cracks.
I would replace the brass tubes with copper.
  • Gravitywell
« Reply #5 on: December 06, 2015, 04:25:02 PM »
Wow Geoff....thanks for the catch.  He's absolutely right, I always use copper for my tanks for that very reason. H^^
Glenn Reach
Westlock, Alberta
« Reply #6 on: December 06, 2015, 06:00:33 PM »
Geoff,
We used brass for years and years and years in R/C.  n~
However, I will change those brass tubes to copper tubes.
Thanks for the suggestion and the replies.
Charles
« Reply #7 on: December 13, 2015, 05:15:39 PM »
C,
What are you putting this in? If scale then the conventional venting would be OK. If Stunt you might want to consider doing uniflow with a second clunk line (you will use this to fill also) that ends about where the pick-up clunk go into the silicon tubing. Use soft, thin wall silicon tubing - the clear stuff not the blue. Keep the copper pipes short as they come out of the rubber stopper (say 5/16" ish) to give maximum flex to the clunk lines.
Best,    DennisT
