  • August 02, 2025, 03:54:19 PM
Author Topic: Brodak .25 Prop?  (Read 958 times)
Offline Kim Mortimore
Brodak .25 Prop?
« on: June 05, 2009, 11:57:45 AM »
What props are y'all Brodak .25 owners using for stunt?
Kim Mortimore
Kim Mortimore
Santa Clara, CA
Offline Jim Oliver
Re: Brodak .25 Prop?
« Reply #1 on: June 05, 2009, 01:07:47 PM »
Using an APC 9x5 on my F.S. arf/B25 combo.  Good prop and I needed the nose weight.........
Jim
Jim Oliver
AMA 18475
Offline Steve Holt
« Reply #2 on: June 06, 2009, 07:16:33 PM »
Depending on the airplane, the RSM 9X6 might be a great choice.  On my light Feno, it worked very well except that I needed to add nose weight with the light prop.  I plan to try it on my light weight Ringmaster.
Offline Allan Perret
  • Proverbs
« Reply #3 on: June 06, 2009, 07:50:50 PM »
APC 9 x 5 working great on my 25 oz Ringmaster.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #4 on: June 07, 2009, 12:57:31 PM »
Flying a Brodak Magician using a Top Flite 9-6.  Other prop is Top FLite 10-4 or even  a 5.  A lot depends on how much plane weighs and what kind of run you want.  DOC Holliday
