Hi Randy:
A quick run down to the garage reveals the front of the tank is 4.5" behind the NVA, and (more relevant I would think) the end of the clunk line is 8" behind the NVA. I think this may well be the answer to the "surge on takeoff" (sometimes even followed by engine stopping)...I had not taken into account the length of the feed line. I have room to move the tank at least 1.5" closer to engine.
The engine is on 1/16th shims, needed to get the thrust line to line up with the cowl opening, but the tank is on the bearers, i.e. 1/16 above the NVA centerline when model is upright. Probably should get it even as a starting point.
Plumbing is: Feed line brass tube at 9:00 position (seen from front of model) with slight angle inside tank to point the flex tube at rear outside corner of tank. Clunk moves freely from top to bottom of rear outside corner. Copper ram air tube on outside of nose, connected with fuel tubing to vent line of tank at 4:00 position. Vent line inside tank is solid brass, curved to about 3/4 of the way to the outside rear corner (thus "kinda uniflow"). Overflow line from top of tank out opening in bottom of cowl. Tried running with overflow plugged (which I would expect to work best) and open (which did work best).
Perhaps should re-do the vent/uniflow line to tie it to the clunk so they move together, a setup that works great on the round 6oz clunker feeding the ST51 in my Score (with overflow blocked during flight).
I will try to post a photo.
OK, now this definitely IS a hijack. Sorry, Larry.
