  • June 19, 2025, 11:35:19 AM
Author Topic: Tank height on pipe applications.  (Read 1380 times)
Offline Wayne J. Buran
« on: May 30, 2006, 03:40:05 PM »
Randy, given that I choose to use a metal wedge tank, in an inverted engine application what should the relationship be for the pick up and the NVA? How about plastic tanks? Any ideas on total fuel required for a piped 51-65s with standard venturi set ups.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Online RandySmith
Re: Tank height on pipe applications.
« Reply #1 on: May 31, 2006, 09:57:04 AM »
HI Wayne
I use  5 3\4  to 6 ounces with my  PA 51
I use  6ounces  with the 61
and  I use  6.5 ounces with the 65
Other  will use  the  same  or  a little  more
as far as the tank goes, typically a  1 inch tank will sit on the  same  plane  as the  motor,  or  be  shimmed  just  off of the beams  maybe  1\16 inch
If your  using  metal pads on top of the motor mounts  you will need  to add  at  least  that thickness  as  a  shim  under  the  tank
With thicker plastic tanks  you should be  OK  as  long  as  your  running  a  motor pads  under  the engine.  if  you  have  to move  the  thick tank  closer  to th e motor mounts  and  have  zero  room.  you can  just  move  the  uniflow  tube  upward  toward the mounts,  this  has  the same  effect as  moving  the  tank
