  • July 14, 2025, 12:20:14 AM
Author Topic: Tank Aggravation  (Read 4853 times)
Offline Chris Fretz
Tank Aggravation
« on: June 09, 2016, 06:25:50 PM »
Well I thought my tank was ok in my Nobler, but it's not. I was working on my run time for the beginner pattern for Brodaks an it's fine upright except it runs like a bat out of h.e. double hockey sticks during the inside loops an upside-down it runs rich. I tried a few different setups with no luck.  I can't move the tank as it just fits.  4oz clunk on pressure . I just tried this get up http://www.tulsacl.com/ClunkTank.html I'm not even sure this setup didn't make it worse. I guess a uniflow setup isn't going to magically fix my problems but I hoped it would.
I pretty much have the same problem with my Mustang I want to use at Brodak's, except it don't run like crazy on the inside loops just rich upside-down.
At this point I guess I'm going to have to live with it, cause I seem to have no end of trouble with tanks, either metal or plastic. I don't understand why this is so difficult.
Anyways, do a lot of people in competition have uneven runs or am I going to be the only one looking like a goof?? ''
Formerly known as #Liner
AMA 1104207
Advanced
Offline Gerald Arana
Re: Tank Aggravation
« Reply #1 on: June 09, 2016, 07:23:47 PM »
Chris,
Put a "Z" bend in the feed line and twist it down (right side up) and/or up when the plane is upside down. I learned this trick from Jim Aron and it works!
Hopefully you have enough room to do this.
Good luck, Jerry
« Reply #2 on: June 09, 2016, 07:51:00 PM »
Chris,
You didn't mention the engine/prop/plug/fuel. If it runs away but comes back after say 1/2 a lap it is likely getting to hot (happens a lot on older mufflered non ABC engines). One thing that works is to reduce the prop diameter by 1/2" or up the nitro % a bit.
The rich inverted is the tank being mounted to low (when the ship is sitting upright). The tank uniflow may be off center causing the condition you describe and will also contribute to the lean run on the inside loops. You would need to move the tank up toward the mounts (upright ship position) or do the uniflow bend trick.
Best,   DennisT
Offline Chris Fretz
« Reply #3 on: June 09, 2016, 08:20:01 PM »
Chris,
Good luck, Jerry
Do you have a picture of this?
Chris,
Best,   DennisT
LA 46, 11.5x4, os#6 plug, 10%
I can't move the tank up it is already up as high as it will fit.
I don't know, sounds simple but not for me...
AMA 1104207
Advanced
« Reply #4 on: June 09, 2016, 09:33:07 PM »
   If you can't raise the tank, lower the engine. If your Nobler is the ARF version, this is kind of a common problem. Mount the engine on 1/8" aluminum pads, and test fly with out the cowl. If it reacts the way you want, you may try thinner pads, or shim the tank with 1/32" shims.
  A round 4 ounce Sullivan tank may work for you, fits up between the motor mounts a bit more, and you can rotate the stopper a bit also in the direction you need to go. This is what I did on one of my son's ARF Noblers to get the run correct. Once you have teh run even, than you can re-work the cowl or make a new one.
« Reply #5 on: June 09, 2016, 09:35:17 PM »
No, it's not simple.  So don't worry about that part.
The "Z-bend in the uniflow" method is for when you have a solid uniflow (which I recommend).  The effective height of the tank is the height of the uniflow outlet inside the tank (which is why I don't like the "uniflow clunk" notion -- it's not really uniflow, IMHO).  So if you can adjust the fixed uniflow's outlet up and down, then you're effectively adjusting the tank.
« Reply #6 on: June 09, 2016, 10:18:10 PM »
and there will be literally hundreds of people at Brodaks who can help you sort it out, and most of them would RELISH THE CHANCE to help
« Reply #7 on: June 09, 2016, 10:33:19 PM »
What?  Control line folks are helpful?
« Reply #8 on: June 09, 2016, 10:35:46 PM »
a couple of them are, most of them , especially the ones named "Tim" and "Mark" tend towards smart alec
Offline Chris Fretz
« Reply #9 on: June 10, 2016, 03:44:58 AM »
It's an old green box Noble.  I don't know how much different it is from the ARF. Good ideas though.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #10 on: June 10, 2016, 03:46:55 AM »
No one has a picture of this Z bend in action?  I don't really get it ???
AMA 1104207
Advanced
Offline Phil Krankowski
« Reply #11 on: June 10, 2016, 06:10:57 AM »
I just had a light bulb moment.  The Z-bend is in the VENT line, specifically the uniflow vent, so it is controlling tank head via where the air gets into the tank (think about hand washing a glass in the sink and lifting a glass of water with the glass upside down)  By adjusting the vent location (turning the bent pipe) it is like taking a flex drinking straw and hooking the rim of the glass to slowly let air in.  (OK, if you don't have kids and occasionally do hand washing this might be an experiment that needs planned and setup instead of just happening)
I am still a little fuzzy about the exact geometry.
On my clunk uniflow setups I try to arrange the rigid uniflow vent even with the spray bar.**  The clunk should be free moving.  The third line is optional if you don't mind standing the plane on the wingtip to fill the tank.  The third line is a standard tank top vent and gets plugged after the tank is full.
Phil
** I did not realize this is what I was doing until now.  This is the light bulb moment arranging the vent to be even with the spray bar.
« Reply #12 on: June 10, 2016, 09:54:07 AM »
Use ze hard uniflow tube.
Make Z-bend in ze hard uniflow tube, so that ze tube just clears ze outer tank wall when ze uniflow tube is straight back.
Ze height of ze outlet of ze uniflow tube inside of ze tank is ze effective tank height from ze perspective of ze engine.
Because of Z-bend, if you rotate ze end of ze uniflow tube outside ze tank, ze outlet of ze uniflow tube inside ze tank will move up or down -- zis is how you effect ze adjustment of ze uniflow with Z-bend.
Offline Chris Fretz
« Reply #13 on: June 10, 2016, 10:13:28 AM »
Thank you for that cool drawing! I'll give that a shot! Is the end/lenght of the Z tube critical to the pickup? I'm glad I didn't try to literally shove a Z shaped tube.in Ze tank! I guess this is just a different variation to that John Miller picture you gave me many topics ago? (I can't view that picture anymore since the crash)
AMA 1104207
Advanced
« Reply #14 on: June 10, 2016, 10:41:30 AM »
Important things:
  • Don't block the end of the uniflow tube with the wall of the tank.  This isn't easy to do, but hey -- someone will think of it
  • Make sure that the uniflow tube doesn't interfere with the action of the clunk.  Zis is why Z-bend -- you could put the end of the tube in the right spot with a simple bend at the end, but then the clunk tube would be always getting stuck on the bend.
  • when the fuel no longer covers the uniflow tube, it's not a uniflow tube any more.  So you want it as far back and as far out as you can get it without messing up with the clunk -- but the clunk moving freely is way more important
  • NO LEAKS!
    • If you have a small leak in the front of the tank then it'll be "the other vent", and as soon as it's uncovered it'll destroy the uniflow action.
    • This is why, any time someone says "my run is great until halfway through and then it leans out", a dozen experts will pile on and say "check for leaks"
    • So when you get the tank done, pressure test it.  I block all the tubes but one, shove it under water, and pressurize it with my fueling syringe.  No bubbles == happiness.
« Reply #15 on: June 10, 2016, 10:44:12 AM »
Just a comment:  If your goal is to fly Beginner, and if your run is good enough that you can stunt in the beginning, stunt at the end, have enough time, and don't destroy the engine in the process -- then your run is good enough for Beginner.  If you really belong in Beginner then you're not going to be held back that much by a mediocre engine run.
I'm not saying to stop working on the problems -- just don't let any minor problems keep you from going to a contest and flying.
« Reply #16 on: June 10, 2016, 11:41:47 AM »
and further, EVERY contest I have been to, there are generally at least a half dozen guys watching the beginners fly and chomping at the bit to help them sort out obvious problems because,, well because if they dont help you, then you get frustrated, then you dont show up anymore, and then they dont have anyone to fly with anymore,
so the key is to let them help you, they feel good for helping, and you feel good cause you learn,,
