  • July 10, 2025, 01:49:27 PM
Author Topic: Supertigre G21/.35 for a stunt engine????  (Read 4356 times)
Offline frank mccune
« on: April 24, 2017, 08:11:32 AM »
      Any comments re using this engine to power a Stunt airplane?
        Tia.
        Frank McCune
Re: Supertigre G21/.35 for a stunt engine????
« Reply #1 on: April 24, 2017, 09:26:31 AM »
   If it's the baffle piston version, it will work quite well. If it's the flat top piston, that is the combat engine, as far as I know. You might want to search that here. I have seen and heard several .40s and they did a great job.
Online Howard Rush
« Reply #2 on: April 24, 2017, 12:52:05 PM »
The Jive Combat Team cannot condone this.  Would you convert a vintage Ferrari to a pickup truck?
« Reply #3 on: April 24, 2017, 03:41:44 PM »
Bob Baron used a ST G.21 .35 in his PA-8, which was published in AAM. One of the earliest examples of running a 2-2-2 with a 4" pitch prop.
But I wouldn't do it. It'd be like driving a Prius to the NATS and leaving the Bentley at home. LL~ Steve
« Reply #4 on: April 24, 2017, 09:39:03 PM »
Any combat/high performance single bypass engine with great flow and larger crankcase volume will have the same problem on a profile plane, which is flame out when you hit down elevator.
         Have you ever looked at a combat model airplane? They seem to all have their engines mounted in a profile plan form. I have timed and watched MANY combat matches, and have never once seen any of them flame out on a down elevator input. I have used Fox .35 combat specials of balloon bust and sport models and have done the full pattern with them and have never had a flame out. I have run Fox .15,.19,.35s, OS .35s, .35FP .40FP, LA.40 and .46, McCoy .19 and .35,  all mounted in side winder fashion and have never had a flame out. Must be sumpin that you're doin' wrong.
« Reply #5 on: April 25, 2017, 08:35:31 AM »
Bob Baron's G21/35 setup worked well.  It seemed like the low-reving 2-4-2 guys didn't like his style one little bit.
He also shunned the lavish fixation to score a few more appearance points and flew models that were neat but to not garish.
Maybe the stunt community's reaction to Bob was more of a factor than the success of his technology.
Offline Jim Carter
« Reply #6 on: April 25, 2017, 09:29:38 AM »
LL~ LL~  I assume you are equating the Bentley to the "astonishing, astounding, fabulous, fantastic" FOX .35!!  ;D  LL~ LL~
« Reply #7 on: April 25, 2017, 07:31:52 PM »
The rash of Nats wins with the K&B 45, ST 46 and G21/35 must have been a bitter pill for Fox 35 Stunt purists.
« Reply #8 on: April 26, 2017, 04:25:27 PM »
Not at all. I was merely suggesting that a Bentley would be swell transport to the NATS, which is always 2,500 miles away. It's the wheels of choice of all the big Rap Stars, you know.  ;) Steve
« Reply #9 on: April 26, 2017, 08:55:42 PM »
OOPS.
And HE called BENTLEY ' the Worlds Fastest lorry ' .  :-\
Anyway , unsilenced , a 21/35 with the supplied small ( 1/8 in. ) venturie , in a nobler Sized Sucker ,
growls round the schedule , with a exotic exhaust note , unobtainable from lesser engines .  S?P S?P
Offline Ken Burdick
« Reply #10 on: April 27, 2017, 10:23:16 AM »
I agree with Howard, but if the st is a ferrari, then the Fox .35 must be a fiat........ LL~
Offline Jim Carter
« Reply #11 on: April 27, 2017, 10:40:44 AM »
;D
Offline Skip Chernoff
« Reply #12 on: April 27, 2017, 06:01:40 PM »
I think Allen Iverson of the 76ers had like ten Bentleys at one time......but he doesn't have 'em now!
Offline Terrence Durrill
« Reply #13 on: April 30, 2017, 09:17:15 AM »
                             YES  ......  an old farmer in Missouri.    LL~ LL~   LL~
