  • July 18, 2025, 08:54:40 PM
Author Topic: Super Tigre replacement needles  (Read 2227 times)
Offline Russell Shaffer
« on: January 04, 2015, 01:11:07 PM »
Is there a source for replacement original metric Super Tigre needles?  Or does anyone have a couple they would part with?  Otherwise I have to change out the assembly to get matching threads.  Thanks, Russell
Russell Shaffer
Klamath Falls, Oregon
Offline Balsa Butcher
  • High Desert Flier
Re: Super Tigre replacement needles
« Reply #1 on: January 04, 2015, 02:13:25 PM »
 Eric Rule/RSM sells ST needles separately. They should work.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: January 04, 2015, 03:21:23 PM »
Russ,
Yes the RSM needles work in the ST spraybar. I just used one in my Fox with the ST NVA, original needle was to short so I swapped it with the RSM unit, works great.
Best,          DennisT
« Reply #3 on: January 04, 2015, 04:54:01 PM »
Thanks for the info.
Russell Shaffer
« Reply #4 on: January 04, 2015, 09:39:24 PM »
Russ,
Best,          DennisT
  You don't want it to be any longer than necessary, to avoid excess vibration.
« Reply #5 on: January 05, 2015, 08:51:39 AM »
I have a couple of old Tigre engines and also several replacement Super Tigre style needle valve assemblies on other engines.  The parts do not interchange - I think some of the clones have U.S. thread sizes.  They work fine but I can't use those needles on my genuine Tigres.  Some of the replacements came from Tower and others from Leonard at Stuka Stunt and I don't know which is which anymore.
Russell Shaffer
« Reply #6 on: January 05, 2015, 09:33:41 AM »
Rus,
The needle from RSM has the ST thread. I also had others that were US thread and it doesn't thread in smoothly. If in double talk to Eric when you order.
Best,         DennisT
