  • July 11, 2025, 04:19:54 PM
Author Topic: K&B 61  (Read 1270 times)
Offline Tom Taylor
K&B 61
« on: July 03, 2007, 07:42:49 AM »
Does anyone know how to or if I can put a remote needle valve assembly into a K&B 61? ???  I have one that I want to try in a Score. #^
Tom Taylor AMA 23014
Offline Jim Oliver
Re: K&B 61
« Reply #1 on: July 03, 2007, 08:37:33 AM »
Tom,
Try  http://www.mecoa.com/kb/61/61-parts.htm
Look near the bottom of the list for part number 985-002.
Jim
Jim Oliver
AMA 18475
Offline Gary Anderson
Re: K&B 61
« Reply #2 on: July 06, 2007, 03:21:41 PM »
Hi Tom, did you get time to try your K&B 61 on the score? I'm working on doing the same, was just wondering how it worked out. Are you using the ringed 61 or ABC type. I have a veco that is a dykes ring and a single ring type, K&B. Have a great day, Gary
Gary Anderson
Re: K&B 61
« Reply #3 on: July 09, 2007, 03:56:19 PM »
Hi guys, I flew my Score with the K&B ring 61. Using an APC 13/6, engine turning 6800 rpm level, turn engine nose up changed to 8200 rpm. What a beautiful engine, lap time 5.22 seconds, good pull anywhere you want to put her. I have the score tank and she ran over five minutes. With the K&B 61 this ship weighs out at 65 ounces. I have another score with a Merco lite case 61 and she weighs out at 60 ounces. I believe the K&B makes more power and rpm varies a little better than my Merco. Man, what a great day, put several flights on this baby and does she ever fly, Wow. Keep them in the air, Gary
Gary Anderson
