  • July 17, 2025, 07:55:15 AM
Author Topic: Super Tigre g21 46 racing spinner?  (Read 1574 times)
Offline William Fann
« on: February 25, 2019, 09:33:50 AM »
What is the 46 racing spinner and is it a different from the standard G21 46?
Re: Super Tigre g21 46 racing spinner?
« Reply #1 on: February 25, 2019, 09:47:44 AM »
    I haven't heard of that before, presumably they mean a spinner with a backplate combined with a thrust washer (replacing the stock thrust washer). But the G21/46 and "racing" don't seem to go together. I would guess the G21/29 thrust washer would fit a 46.
   Where did you see a reference to this?
Offline Peter in Fairfax, VA
« Reply #2 on: February 25, 2019, 11:43:42 AM »
Yes, when I think of racing and Super Tigres with spinners, I think of the G15, with its spinner, or the G21/29 with its spinner.  Other racing displacements are .40 and .65, like the X40, G40, G65, but no spinners.
« Reply #3 on: February 25, 2019, 12:16:14 PM »
I have a couple of G21 29s  and that was the  only one of the  G-21  series  that I remember  coming  with a spinner
« Reply #4 on: February 25, 2019, 05:26:16 PM »
The ' Racing ' spinners were avaliable seperately , as an ' accesory '.
Theres the .15 size , 21 series size . ( maybe a few 40 RV's came with them std. ) and the 60 size with bobbin   backplate/ driver -
which should fit the 46 too , maybe . I assume the shaft is the same diameter there.
There were also two or three std. Super Tigre domed ' Stunt ' spinners . but METRIC sized . 50 & I think 60 mm dia .
Some of Compostellas Tango's had those .
Been a few of all N I P on R C groups , over the years , and E Bay .
« Reply #5 on: February 25, 2019, 05:30:44 PM »
Thississthe 60 /65 type one , Eh .
And a real very stunt one . 2 1/8 dia , 55 mm / I think .
Any complaints , see the Manager .
but no spinners.
OH YES THEIR IS  . The G 60 RV ABC renowned first 200 mph R C & CL came with the set up ,
Think theyre 1 3/8 & ' Go On ' the 46 shaft , but may leave it a bit short .  :(
Mayaswell put the full Two Pages on , as its a bit histronic , being the FIRST ABC & inventor & all .
Though somebodys lost 2 mph somewhere , maybe they found it later .
« Last Edit: February 25, 2019, 06:01:04 PM by Matt Spencer »
« Reply #6 on: February 26, 2019, 07:46:45 AM »
I saw a G21 46 on eBay where it had stated it had a racing spinner.  Then there was no spinner pictured.  I know what a spinner is but wondered if he was referring to something else.  Anyway, thank you all for your inputs.
