  • April 19, 2024, 06:16:46 AM
Author Topic: Super Tigre G21/.46 Bearings  (Read 811 times)
Online Peter in Fairfax, VA
« on: March 13, 2019, 12:36:46 PM »
So I have a G21/.46 with an RSM venturi.  Do I need to change out the bearings, or are the factory ones adequate?  I know the G21/.35 bearings are poor, and wonder if the .46 has the same issue.
thanks,
Peter
Re: Super Tigre G21/.46 Bearings
« Reply #1 on: March 13, 2019, 08:28:11 PM »
   The factory bearings are fine on the entire G21 series, as long as they do not get rusty or are improperly lubricated. Don't replace them unless there is a problem. Same goes with all disassembly, only take it apart if required, otherwise, leave it alone.
    If there is a problem, get the cheapest possible replacements from Boca (I think it is ENK-079).
« Reply #2 on: March 14, 2019, 02:52:49 PM »
thanks,
Peter
If you are  going  to take  it apart  then  YES  replace the bearings, The front bearing  should have a  rubber seal on it.  I have  many bearing sets in stock , 46 included,  The stock factory bearings would be  near  over 40 years old by now,  so good idea  to do it
I also have  many parts for the  46 including  rings
If you need any parts  ar help let me know
Randy   678 407 9376
