  • June 17, 2025, 02:43:20 PM
Author Topic: Tank for PA .40  (Read 822 times)
Offline mike londke
Tank for PA .40
« on: August 11, 2020, 04:41:54 PM »
How much fuel will a PA 40 use to get through the pattern? Early version not the UL. Thx
Re: Tank for PA .40
« Reply #1 on: August 11, 2020, 05:10:13 PM »
  It depends, I seem to recall running something like 5.5 ounces, although you could set it up to make it on much less.
Re: Tank for PA .40
« Reply #2 on: August 11, 2020, 07:11:42 PM »
I used a  6 oz  tank, and took out  1/4 ounce,   so  5.5  to 5.75
Offline mike londke
Re: Tank for PA .40
« Reply #3 on: August 11, 2020, 08:32:48 PM »
Thank you both.
