CLICK HERE--><--CLICK HERE
Super Tigre C 35 Venturi Seal Source
Started by Roy Lane, October 04, 2026, 03:26:27 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Roy Lane
I was gifted a Super Tigre engine, my first time to have one. Great compression. The venturi seal was dry, brittle and cracked. I have searched EBay and other standard sources with no luck. Any source for these or a correct O ring size. I have a variety box of O rings. The correct diameter size is too thin. Auto part stores don't have the cabinets of loose stock to look thru anymore. I could double up what I have. This is a spray bar type venturi. Don't need to induce any issues. Thanks in advance!
Roy Lane
I actually have a C35, not a G21 35, flat top piston engine. Need to source the venturi seal. I found the edit button :)
  Take the venturi to a hardware store and check their stock.A power transmission supply place that carries bearings , seals and such for industry may have an assortment alsoMcMaster-Carr is another source, but you will need to know the size to order on line or by phone.
  Good luck with it!
Motorman
#3
That's a 1/16th square shaped rubber gasket. They do get brittle. If push comes to shove, you could put it together then dab some JB Weld in the gap as a last resort.
I'll pull out my S/T stuff later and see if I have an O-ring that would work.
Ok I'm back. The (round) O-ring you want is 1/2" x 3/8 x .075 Buna-N rubber.
Roy Lane
Thanks Motorman! I may have found a source at Happy Hobby Shop in Milwaukee with the actual Super Tigre part. Will have to call tomorrow and confirm.
Roy Lane
I recommend anybody looking foe engine parts to call Bob Brooks at The Control Line Store on EBay. I need to follow my own advise. Bob had what I needed and then some! Parts are on their way.
