Fuel is getting to be more and more expensive
This is a little OT, but the rate of increase of fuel cost seems to be tiny in comparison to, say, gasoline. I was paying about $10/gallon for fuel when I when to my first contest in 1981, and it was the absolute cheapest I could get (home-brew, or back room of Lew McFarland's pharmacy-brew). I just got a new case of semi-custom fuel for a little under $17/gallon. That's almost exactly the inflation since then. I could get conventional fuel for around $13.50, so I contend if anything, the constant dollar cost of a gallon of fuel is actually lower now.
Gas was about $1.25/gallon in 1981, and about $4.25 now, way ahead of inflation, and it is definitely less effective than it was in 81.
Th increase in glow fuel cost is offset further by using it more effectively. I was using about 5 oz/flight to fly an wimpy St46 on 5%, and close to 6 oz on 10% (to compare apples to apples), and a fair bit of it ended up gooped to the bottom of the airplane (increasing paper towel costs astronomically, like 1/2 roll per flying session) I now run about 6.4 oz/flight on the mighty piped 61 and use 3 sheets of paper towels. I could switch to something that was nearly as effective and runs 4.5 oz per flight and takes 1 paper towel per session.
It is my considering opinion that my per-flight recurring cost of glow is probably less than it was in 1981 in absolute dollars, and could be reduced. Cost per "unit effectiveness" is much better now. Adjusted costs are certainly much lower.
Even further OT, since someone was complaining about it in another thread - engine cost. In 1981 I paid about $75 each for bone-stock ST46s (conventional units right off the big production line). Of course you can't just have one of them, because the ring tended to go over the hill at inopportune moments. So, say, carry 2 of them with you, and have the 3rd in reserve. That's $225, not considering the trick RPM or SST muffler (another $20-40) and the big box of props (say, 10 of them at $1 a piece but about an hour of labor reworking them, say at $4.25/hour, so $52 for your box of props). 10 years of an ST could be the same 3 engines, but maybe 25 rings, 5 sets of bearings, 3 dozen props, two head gasket sets, and maybe 5 venturis. Ignore the "fiddling-around-with-it-in-a-hot-field-for-hours-just-to-get-it-to-put-out-enough-power-at-the-right-time" time, that's part of the "fun".
I can get a RO-Jett for around $400, and that was the about the same at the PA. I went about 5 years at the highest levels with no backup engine when I had the PA, with two pipes and two headers, for a total of about $600 for everything including the two props I actually needed (forget those I got and didn't need) since you can endlessly adjust them. That also is about a wash in absolute dollars and a bargain in constant dollars. And, it works MUCH better.
For even cheaper, I got an engine/header/pipe from Alan Resinger for $125, and I ran that for about 10 years with no maintenance, with two Bolly fiberglass props I got for about $18 a piece, unfinished. That outright cheaper than trying to compete with ST46s (which, truth be told, I *wasn't* competitive in any way with an ST46).
I think the cost of the equipment/recurring fuel, parts, etc, cost in stunt has, if anything, gone down since I started doing, and pretty drastically compared to inflation. Even if you ignore the fact that just about all of it is *far better* than we had in 1981. And compared to my personal resources, it has become nearly negligible. I got $440 a week when I hired into Lockheed in 1983, let's just say it's a bit more than 150% of that (roughly the inflation since 1983) now.
