  • June 22, 2025, 12:23:42 PM
Author Topic: OS 25 FP & 2mm socket head screws  (Read 1648 times)
Offline John Craig
« on: August 30, 2014, 03:01:12 AM »
Trying to disassemble an OS 25 FP  3 of the 6 head bolts came loose with out an trouble.  The remaining three will not budge.  When I put downward & twisting force, I will finally hear a little pop & feel movement. Only to see that the pop was the sharp corners of the Allen Wrench giving way.   HB~>
SUGGESTIONS?
Re: OS 25 FP & 2mm socket head screws
« Reply #1 on: August 30, 2014, 07:52:42 AM »
You can saw off the end of the wrench and go again.  Maybe with a heat gun this time.
Offline John Eyer
« Reply #2 on: August 30, 2014, 09:11:25 AM »
You might try Sears stock number 966197 Screw Extractor.  Follow instructions labeled 1,2 & 3 on back of card.   Works great on old Fox 35 Stunts.
Offline dennis lipsett
« Reply #3 on: August 30, 2014, 06:13:39 PM »
Hopefully you are not using 'allen' wrenches or keys bought at harbor Freight or any of the other bargain stores. They aren't made of any decent metal and will always round out easily when pushed.
Online Motorman
« Reply #4 on: August 30, 2014, 06:24:48 PM »
You can use a dremel tool cut off wheel to cut a screw driver slot.
« Reply #5 on: August 30, 2014, 07:08:37 PM »
   Cut off the end, heat it red, then quench it in water. Then try again. If it rounds off again, get a good set (like the relatively inexpensive Bondhus), and you will have no more problems.
Offline rich gorrill
« Reply #6 on: August 30, 2014, 07:29:09 PM »
When removing any screws either allen head or Phillips I hold the engine steady on the work bench insert the allen wrench and give it a sharp hit with a hammer. Sometimes this helps break the bolt loose. It can be dirt or rust holding it, also a good soaking with Kroil or Liquid Wrench helps.
Rich
« Reply #7 on: August 30, 2014, 08:00:44 PM »
   If you have replacement screws ( and you should if you are rounding out the socket also) just drill out the head of the screw. Use a drill a bit larger than the shank of the screw. Drill in until the bit gets to the point where the shank of the screw meets the head of the screw, then the head will pop off. Repeat on the other screw, then remove the head. There will be enough of the shank left above the cylinder to grab with small pliers and finish backing them out. You just need to sure you are using a good quality drill bit, as the socket heads can sometimes be fairly hard.
« Reply #8 on: August 30, 2014, 09:47:45 PM »
No kidding. My fancy Horror Freight 16 piece T-handle set was a crappy investment. I've ground the end of my 1/8" wrench so many times it's going to disappear soon.
