I know that APC 9x4 is a commonly recommended prop for this engine, so I bought 6. The prop shaft holes are so far off center that it's visible by eye. When spinning it on Dubro prop balancer, blades are out of track and it won't balance consistently between spins. For over $2.00 each, that is BS. Does anyone know of another prop that will give a good run on an FP 20? Do I need to invest in brass rod and a drill press just to correct factory defective props?
cheers,
