  • June 25, 2025, 02:15:19 PM
Author Topic: Low compression  (Read 2659 times)
Offline scott matthews
Low compression
« on: April 12, 2012, 07:22:18 PM »
Have you ever purchased a new engine and less than two dozen flights all of a sudden have very low compression. This is my second OS 25 LA and after 3 bench runs on a rich setting and flying a half dozen flights on a 9 x 4 prop now it has low compression. Its so low that trying to start the engine turns into a 15 minute affair, but after it starts it runs good. My set up is a needle valve from OS thru the venturi, an aluminum back plate on the crank, and head and crank bolts replaced with socket head cap screws. I ran maybe a dozen flights using the 9 x 4 apc prop and then shifted to a 10 x 4 apc  prop like I have on my first OS 25. What do you think I did wrong? My flights started out slow and rich with no horse play and I worked my way up to an idle speed that was just starting to break into a rich 2  cycle. I have changed crank case gaskets , checked for a head gasket ,replaced glow plug and gasket, and even pulled the sleeve to see if there was any scaring in the sleeve and on the piston and both look brand new. I have a new piston and sleeve from Tower Hobbies coming soon and will re-break in this engine again but was wondering if this happen to any one else or did I jump up in prop size to soon and ruined a good motor?
Re: Low compression
« Reply #1 on: April 12, 2012, 07:36:27 PM »
My method for break in,
smaller lighter prop, say a 7x4 or so,,
first runs you want it to build some heat, for short runs,, so right at the rich two stroke,, but only like 1 minute or 2 minute runs, letting it cool,
( though some people run it longer and richer, then pinch the fuel line to break it leaner)
several runs like this, then start bringing the rpm up and lean it a little more on each run.
I wonder if you might have run it to cool at first and the liner did not expand from heat like it needs to and it wore the fit away,,
but I am no expert on two strokes, I manage based upon direct supervision LOL
Re: Low compression
« Reply #2 on: April 12, 2012, 08:26:30 PM »
It is very easy to warp the sleeve in these engines when tightening the head screws. I like to remove the glo plug and loosen all of the head screws and retighten while checking for drag on the piston at tdc. I usually snug them down pretty good and then loosen them a little one at a time and again feel the drag. You want to get the least amount of drag with the plug out that you can get, and then put the plug back in to check for compression. Hope this helps.
Online kenneth cook
Re: Low compression
« Reply #3 on: April 13, 2012, 03:53:24 AM »
           Hello Scott, I've never witnessed whatever is going on with your LA .25. We use them in speed limit combat all the time. I have 4 of them and most of our club members use them as well. We take them out of the box, bolt them on the plane give them a few  ground runs and then run the @#$% out of them. I have some real good runners. I just find it hard to  believe that you've damaged the piston liner. I've even heard them squeaking as they're turned over and the engine is fine. I would check everything prior to replacing the piston liner. I would even go as far to put the back of the case in a bowl of water as your turning it over and check for leaks. I would do the same with immersing just the head to check for leaks. I've even seen the top posts of glow plugs leaking around the insulator  and also the copper gasket at the base. Seeing many of these engines in use this past year, I have high regards for the LA.25. I do agree though with what Mark states above concerning the heat cycling of the piston/ liner and the consequences of running an engine like this too rich. Ken
« Last Edit: April 13, 2012, 04:58:04 AM by kenneth cook »
Re: Low compression
« Reply #4 on: April 13, 2012, 09:20:07 AM »
I have a book on the care and feeding of model two strokes.  I can't lay my hands on it so I can't tell you the author (he was motor columnist for MAN or something).  But, in that book were two bits of wisdom that pertain here:
  • According to this guy, you do not want to break in an ABC, AAC, ABN, etc., engine cold.  They are designed so that the running fit gets looser the hotter the engine gets, so if you run them for prolonged periods of time when they're cold you wear them out prematurely.  Iron piston engines are the opposite, so a lot of the tribal knowledge of how to break in an engine is based on them.  (This is consistent with the few engines that I have bought from new -- the one AAC engine was tighter than tight until I hit it with a heat gun; it's only gotten out of the "squeaks when cold" stage, but it's always loose just after its been run).
  • You should always follow the manufacturers instructions for breaking in the engine -- that trumps anything that I say, or that you may have thought, or anything else.
So, if the above is true, then the only thing you should do in response to this post is to do whatever OS says to break in the engine, and completely blow off what I (or anyone else other than OS) said about break-in.
Re: Low compression
« Reply #5 on: April 16, 2012, 02:45:24 PM »
The manual for the OS LA series recommends running the motor one running rich for 3-4 oz. of fuel.  Then put it in a plane and fly it at a leaner setting, gradually leaning it out for 5 or 6 flights.
Like Ken above, I've had good luck with very little break in.  Basically mount it in a plane.  Start it up and set the needle just rich enough to break into a four cycle.  Let it run 3-4 oz. Every 20-30 second lean it out to a two cycle for 30 sec. and then back to just into a 4 cycle.  After a couple break in runs its set to go, either flat out two cycle, or in a 4 cycle or 2-4 stunt run.
Re: Low compression
« Reply #6 on: April 16, 2012, 07:37:27 PM »
HI Phil,
Slightly off topic, but tell us how you get the LA series to 4-2......... I can't seem to get a reliable 4-2 run out of any of them.
Thanks!
Offline L0U CRANE
Re: Low compression
« Reply #7 on: April 17, 2012, 06:22:48 PM »
Bill, may I ask why you want an LA to run in 4/2?
I understand that to those of us who were "there, then," that run mode sounds more "right." The newer engines, affordable ones, that is, weren't generally designed to do that. They were designed for a wider range in 2-cycle, and the right choice of prop, plug, fuel and load can deliver solid, dependable power without fuss...
A 4/2 run seems more suitable to engines which have a short range in 2-cycle, set to run rich enough to 4-cycle under light loads at near the top RPM they can achieve on the prop, fuel, plug. When airloads increase, they switch modes. The newer engines simply stay in 2-cycle through slight changes of RPM caused by loading and unloading the setup.
Forcing an engine into 4/2 mode seems to me to require load conditions that pull the usable RPM well down from the designed-in best RPM range. So we forfeit power potential, and complicate the use of engines intended to be dependable for RC flight, where many fliers think a 4-cycling setting means the engine isn't running right.
\BEST\LOU
Offline Andrew Tinsley
Re: Low compression
« Reply #8 on: April 18, 2012, 08:57:26 AM »
Hello,
The only times I have suffered from the type of behavior that you are seeing is as follows. Cox 0.049, during run in it was fine, Did one flight and totally lost compression. Culprit here was a leak had developed in the glow head insulating seal. Second time this happened was with an LA46. Broke it in as per schedule and after 10 flights , no compression. This time it was a leaking backplate, a couple of the screws had come loose.
Look for the simple stuff like leaks before you start getting complicated.
Andrew.
BMFA Number 64862
Re: Low compression
« Reply #9 on: April 18, 2012, 11:38:57 AM »
And to think that I pride myself for being the guy who points this stuff out  :-\.
Of course, in my private life I've been known to have a piece of electronics half disassembled and hooked up to an an oscilloscope before I realized that the power cord was unplugged...
Glow plugs, heads, and backplates can all leak, and they can all cause problems.
Scott, If you don't know how to check for leaks, ask -- we'll tell.
Online kenneth cook
Re: Low compression
« Reply #10 on: April 18, 2012, 01:54:43 PM »
          I should've added this in my earlier post, this is not related to the low compression issue but could surely be a problem in general. I had posted this problem on this site as well as Stuka Stunt. You didn't mention though who made the backplate. I contacted Curtis Ship who was also making metal backplates. Curtis based his machined backplate from the stock OS plastic ones. The one change he did make which is all for the better was to add an internal o-ring. I happened to have a new FP.25 backplate which I installed on the engine as soon as I pulled it out of the box. It fits the LA case perfectly except they're not identical to the stock unit. The FP backplate doesn't protrude into the rear of the case as far as the plastic unit does. While the engine was running, the rod was starting to work off of the crankpin and thus the engine would start to bind and slow down. After exploring several items a club member took the engine apart to discover the actual problem. I haven't had this problem with other LA's .15,.40,.46, only on the .25. This would be something I would surely check. Ken
Re: Low compression
« Reply #11 on: April 18, 2012, 02:36:25 PM »
Hi Lou,
Just curious!  I have not seen the LA series of engines run in anything except a "wet 2".  Never in a 4-2........ so I was curious as to how Phil was getting them to run in a 4-2 in stock condition.
I run them in a wet 2 as that is where they like to run.  I wish I COULD get them to put out the same power in a 4-2, but it ain't happening! LOL!!
Offline L0U CRANE
Re: Low compression
« Reply #12 on: April 18, 2012, 04:01:56 PM »
Scott, going back all the way to post #1...
No one has yet mentioned the fuel blend. I'll presume you used a typical 10-10-10 (Nitro - synth oil - castor) blend, which should be safe.
If you used an all-castor fuel, you may have never reached the intended warmed-up expansion temperatures, and may have started building a castor varnish to the piston. These are not good for an Aluminum-(Plated)Brass engine.
Other aside comments - I've run in a few dozen OS ABN engines, mostly for others, and typically found that the first start is not guaranteed to be easy. Exhaust residues show dark from burnishing the initial fit for the first, and sometimes as long as to the 4th or 5th, brief bench run. Things get better rapidly after this stage, and it probably takes 6 to 10 flights to reach a durable plateau after it.
Haven't heard others remark on this...  Starts at previous flight settings usually benefit from two things.
... First, If you use the stock muffler for muffler pressure, goose the fuel supply by tapping the outlet while the engine spools-up/warms-up during the first 3 or 4 seconds of running.
... Second, keep the glow plug battery attached during this time, too. You should hear it 'get on the step' and lock in before pulling the battery.
Launching before full launch RPM and temperature are reached may explain some complaints I've heard/seen.
\BEST\LOU
Re: Low compression
« Reply #13 on: April 18, 2012, 04:38:15 PM »
HI Phil,
Thanks!
This in one motor on one plane.  It's a 500 sq.in. flapless plane that weighs about 30 oz.(about 6 oz. of paint too much).  The LA 25 uses the stock muffler, stock intake, and runs an 8/4 prop at around 10,300 in a 4 cycle on the ground.  Sounds like it picks up a bit in the air.  Took a couple flights getting the setting just right.  It breaks into a 2 cycle during maneuvers, back into a 4 cycle as it levels out.  The key seems to be using a smaller prop.  A 9/4 makes it run hotter and it won't always go back to a 4 cycle.
Re: Low compression
« Reply #14 on: April 18, 2012, 06:23:05 PM »
My engine set up is exactly the same as my two other LA 25, aluminum back plate that I made at work,Sig 10% fuel, OS needle valve thru the venturi, and socket head cap screws to replace the stock screws  in the head and back plate plus the muffler bolts.Also running stock muffler under pressure. My other two engines run great with easy starts and consistent runs in a wet 2 cycle this one is extremely hard to start, has no bump when starting but once started runs fairly decent. I have not had the time to check thoroughly for leaks because I changed engines and the last few days have been great for flying. I will look into this using the advise from the above links.
Re: Low compression
« Reply #15 on: April 19, 2012, 07:21:10 PM »
I sat down today and found the source of my compression leak. After putting soapy water around the obvious spots my engine is leaking air at the front of the head where it joins the motor case . Disassembled  the motor and replaced the piston, sleeve and head gasket, now we are back to a crisp new motor straight out of the box engine. If this happens again I guess I will replace the head  next. I did notice a small deformation that looks like a small casting crack in one of the ports in the case ( I would say this is the spot where you insert a small piece of wood to fix the Fox burp) it does not appear to go Thru the crank case. I do appreciate all the advise that everyone has offered.
Re: Low compression
« Reply #16 on: April 19, 2012, 07:26:19 PM »
Save the old piston and liner -- they're very likely still perfectly good.
Re: Low compression
« Reply #17 on: April 19, 2012, 07:45:08 PM »
I have them in my spare parts box I figure I can always pick up a spare gasket or head next time I order from Tower Hobbies.
Online Dennis Toth
Re: Low compression
« Reply #18 on: April 20, 2012, 08:02:05 AM »
Scott,
The source of the problem is most likely the socket head bolts in the head. On some heads the holes are off by a thousants or two and causes rubbing of the bolt head against the side. You can either go back to the original OS bolts or have the head bolt holes (in the area of the fins and seat) opened. What happens is that the socket head bolts are slightly larger then the seat area and rub against the side as you pull them down. This causes the head to distort and not seat properly. This happens on Foxes when you use the socket head bolts and will cause the engine to bind. As you tighten down the bolts make sure you go in a cross head pattern, keep the plug out and feel the motor as you turn it over make sure it is smooth with a little pinch at the top.
Best,      DennisT
