  • August 05, 2025, 01:12:26 AM
Author Topic: McCoy 29 RR redhead fuel consumption...  (Read 2815 times)
« on: October 18, 2018, 07:07:28 PM »
I'm building two Berkeley Minnows for a B Team Race demo and am using McCoy 29 RR redheads. I'm wondering how long a 1 oz and 2 oz tank would run. I plan on 8x8 prop from recommendations.
Chris...
Re: McCoy 29 RR redhead fuel consumption...
« Reply #1 on: October 18, 2018, 10:06:39 PM »
Id guess 20 to 30 laps , on Niro  , 15 % . AT A GUESS .
the ' Range Brews ' could double the laps , so say half of 70 ( laps ) on 10 % Nitro . = 35 laps . on a good day .
So posably 20 laps on 20 % nitro , with a head wind . S?P .
with the One Ounce 30 cc tank .
Building a Long Gone VI my humble self at the moment .
Wings Done & crutch , tailplane etc. Bare Wood .
Lot of stuffing around , solid wing , for the internal leadouts etc .
Dunno if the OS 30 , H 29 R , or ST 21/29s going in it , yet .
gotanypictures of yours .
p.s.
It might be easyer to fit one ounce in a two ounce tank , than fit two ounces in a one ounce tank .  :-X
« Last Edit: November 15, 2018, 04:18:57 PM by Matt Spencer »
Online Dave Hull
« Reply #2 on: October 18, 2018, 11:03:42 PM »
Chris,
For reference, I believe that the B-TR rules specified a 30 cc maximum fuel load (tank plus lines, filter, etc.)  Since the races were 35, 70, and 140 laps (qualifier, heat and final), everyone fiddled with venturi's and fuel mixes--sometimes between races--to try to gain advantage by eliminating a pit stop somewhere.
I have not run a McCoy. On the modern engines, 30 cc (1 oz.) was a challenge to always get the 35 laps. I couldn't run the largest venturi that would draw. I also experimented with "range mixes." Picked up some laps but didn't like the way it ran, so stopped doing that.
If you are doing a demo, and just want decent runs (a shade rich) without fiddling, just put in an oversize tank?
Good luck with yours!
« Reply #3 on: October 20, 2018, 10:34:33 AM »
Thanks guys,
I am just messing around so if a 2 oz will fit that is what will go in it.
Chris...
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: October 20, 2018, 10:40:41 AM »
From my speed experience, I would suspect 90 to 120 sec on 1 oz with that set up. I'm basing that on 1/2oz would barely get you an official speed run,  about 15 laps, I'd bet. So 1oz 30 3 sec laps.
Oops, math was off
« Last Edit: October 20, 2018, 06:50:52 PM by Dane Martin »
Offline bob whitney
« Reply #5 on: October 20, 2018, 06:26:22 PM »
 just read this post  the McCoy RR will work good for TR but need to use a full body needle valve with a with a venture  re stricter .
1 oz of 10 % should give u between 32 and 35 laps with the 8/8. are the motors ring or slug piston
rad racer
Offline qaz049
« Reply #6 on: October 20, 2018, 09:31:25 PM »
Chris...
I've found the McCoy RR .29 to be quite thirsty compared with an ETA .29, I've run both in the same B Class model/tank. The latter stock venturi gets 36 laps/30cc tank while the former is mid 20's. Changing the venturi hole would fix that.
An alternative is to add about 10-15% Iso Propyl Alcohol to the fuel mix. The least % that works is the best strategy. Modest volumes won't effect running. Normal 99% IPA from a Pharmacy or from a plastics sheet (Plexiglass) source should suffice. So say 15% Nitro, 20% Castor, 15% IPA and the rest Methanol. This would be a very mild range brew. BTW, the ETA started out as a McCoy clone but was developed much further.
Modern engines respond well to simply adding 10-15% Ethanol to the brew in place of some of the Methanol.  Some countries now use 96% Ethanol (rest Methanol) as Mentholated Spirit, formally called "Wood Alcohol". Good for about a 10% increase in range.
Of course the simplest remedy is to increase the tank size a little :-)
« Last Edit: October 20, 2018, 10:07:01 PM by qaz049 »
« Reply #7 on: October 24, 2018, 03:54:43 PM »
Thanks guys,
Bob do the regular mcCoy spray bars restrict them enough for suction opetation?
Chris...
« Reply #8 on: October 24, 2018, 04:08:41 PM »
Thanks guys,
Chris...
No. One of the crew in Pullman, WA had a Mac .29RR in a TomTom. He had to put a Jim Walker pressure tank and regulator in it, to make it give a steady run. Otherwise, it was just plain bad. But I only saw it once, and never with the JW setup. It was loud when it was running strong. No idea what size prop he was running. I'd throw a 4mm spraybar through the stock venturi and run 6 oz of Coleman lantern fuel per gallon to start. You might need to add a filter or some panty hose mesh over the venturi to increase the suck.  D>K Steve
Offline bob whitney
« Reply #9 on: October 24, 2018, 10:27:18 PM »
it will need the one piece spraybar  .if this is just for demo flying I would restrict it until u get a good steady run .with an 8/8 it should still go fast enough .
  if u set it up for case pressure it will really run good  and is easy to work with
rad racer
« Reply #10 on: December 22, 2018, 07:11:57 PM »
Thanks Bob,
Robbed some 1960's .35 Stunt NVA's, got some cute 1 oz RC tanks, ground off enough stuff to fit the .29 RR Redhead into a Berkeley Minnow.
Chris...
Online Dave Hull
« Reply #11 on: December 22, 2018, 07:22:53 PM »
Now that is pretty cool.  I didn't expect the formed aluminum cheek cowls. Nice!
I've been looking at a partially completed Redskin now for a week. I think it's going to have an OS in it. But no cool aluminum cowling pieces....
Divot
Offline Brian Hampton
« Reply #12 on: December 23, 2018, 05:05:10 PM »
Back in the days of B team race in Australia, the engines of choice were the ETA 29, McCoy RR 29 and Enya 29. I very much doubt that nitro was ever used because that would only reduce the range but petrol was quite often added at around 10% I believe.
