  • July 06, 2025, 02:21:05 AM
Author Topic: a-26i have plans to build mike kevills  (Read 851 times)
Offline roger
« on: April 24, 2009, 03:52:57 PM »
i have plans to build mike kevilles a-26 . what wingspan would be right if i put on 2 os. 25s?
roger
Offline John Miller
Re: a-26i have plans to build mike kevills
« Reply #1 on: April 24, 2009, 05:35:26 PM »
Wharever it takes to get 650 -700 sq inches of area.
Offline roger
« Reply #2 on: April 25, 2009, 07:38:27 PM »
 ??? well %^@
« Reply #3 on: May 02, 2009, 05:49:04 PM »
Bearing in mind that Mike's A-26 is a profile scale model, not a stunter, I would think that something less expansive would be a better bet. I'd take a look at 55" span or 500 sq. inches, whichever is bigger. As always, lighter is better, up to a point. If it is too fragile and constantly needs repairs, then you built too light. Repairs do weigh more than building it a tad bit tougher to start with. It also depends on what your flying surface is like...cow pasture or smooth asphalt.  H^^ Steve
Offline John Miller
« Reply #4 on: May 02, 2009, 08:02:32 PM »
Steve, though I don't really disagree with your thinking, 500 sq inches would be fine for a pair of .15's. We're running 620 sq inches on a twin stunter with a pair of .15's.
Of course, a pair of .25's on a plane that small will either race around, or you can run it way rich for a neat 4 stroking sound.  H^^
