  • June 13, 2025, 05:51:21 PM
Author Topic: How to adjust nitro for density altitude?  (Read 3536 times)
Offline Peter Germann
« on: July 30, 2009, 07:51:08 AM »
Without changing pitch, venturi dia and/or compression and presuming that I would aim for the same lap time and the same type of fast 4-cycle engine run, what is the relation between density altitude and nitro content? Does anybody have data on hand quantifying nitro change relative to density altitude?
My home base starting point is 10% nitro for 5.3 sec at a density altitude of 2500 ft. and I am looking for info on how to adjust nitro for 1000 ft. and/or 4000 ft. density altitude. Trivial Pursuit 62 oz  PA .75 2p  13 x4 3 bl. 64 ft x 0.015
Thanks for help
Peter Germann
Online RandySmith
Re: How to adjust nitro for density altitude?
« Reply #1 on: July 30, 2009, 07:58:14 AM »
Thanks for help
Peter
  I do not have any charts, but going up 3000 ft with my setup requires about 5% increase.
I normall use 5% in my setups in cooler months, going to 10% in hotter months, or when I change locations that have higher altitudes.
In the Summer I use a lot of 7.5%. When I was at the US NATs, for example, I take 5 and 10 % fuel with me, it is easy to go from one to the other, or I can mix them and have 7.5% fuel, work perfect as a tuning tool to keep the run the same
You could use 10 and 15% in the same manner, or even 10 and 20%
Offline Alan Resinger
« Reply #2 on: July 30, 2009, 05:02:15 PM »
Randy,
This past weekend we had a contest and I got some strange engine perfoamance.  I"ve been running a Stalker 66RE in my big Eather Firecracker.  I run Powermaster YS Saito 20/20 and runs have been just about perfect for the past 3 years.  The contest weather was hotter than anything I've flown in and on both officials the run was normal until the square eights when the engine leaned a bit and stayed there.  Wasn't unmanagable but was noticable.  Total run time was slightly longer as to be expected.  Sounds like slight overheating to me.  Would adding another head shim be the proper fix during really hot weather or just a reduction in nitro?
Alan
Offline John Miller
« Reply #3 on: July 30, 2009, 05:11:08 PM »
I'm interested in Randy's answer as well. I was always told that more nitro helped in hot weather. D>K
Online RandySmith
« Reply #4 on: July 30, 2009, 06:30:47 PM »
Randy,
Alan
Alan
In hot weather you have to run the motors harder and leaner to do the same job.
And when you add a head shim you will have to lean the needle to get back where you were,not the way to go most times the "best" way to do this in heat is to either up the pitch of the prop, which is the recomended way.
I do this by having the same prop in .2 tenth or 1\4 more pitch, When you up the pitch the needle goes back a little richer setting, this way it runs cooler, and almost exactly where it is in a little cooler weather.
the other way is to add more nitro, and back the needle out to a richer setting, but..since you are already at 20% I would just use a little more pitch.
Many people do both, as this adjust for the loss of oxygen that the motor sees, and for loss of lift in hot humid air,
this also works for FAI fueled engines, run about 1\4 more pitch in hot weather and\or use about 2 to 3% nitro.
At this years NATs, I just went from 5% to 7.5% when it got hotter, then back to the 5% when it got cooler mid week. Others there just went from 10% back to 7.5 when the weather cooled, and at least 2 people that I know of just went from a 4.25 up to a 4.5 pitch prop of identical type.
« Last Edit: August 01, 2009, 11:07:27 AM by RandySmith »
« Reply #5 on: July 31, 2009, 06:30:40 AM »
Thanks Randy,
I happen to have another special prop for Stalker that is 1/4" more pitch.  Have to give it a try in this hot weather we're haviing,
Alan
« Reply #6 on: August 01, 2009, 05:01:13 AM »
Thank you, Randy. I will do as suggested, and keep record and report.
Meanwhile on I have found on:
http://wahiduddin.net/calc/calc_hp_abs.htm
a program calculating relative power of IC engines when entering:
- Absolute Pressure in in/Hg  (barometer at site)
- Air Temperature in °F
- Relative Humidity in %
I wonder if we could use this program to actually quantify the loss of power due to altitude and temperature? If so, all we would want to know then is how much nitro we need to restore power.
rgds
Peter Germann
Online RandySmith
« Reply #7 on: August 01, 2009, 10:29:46 AM »
rgds
Hi Peter
You could probably get very close by using the programs "Dyno Correction Factor" and then multiply by 3 . In other words on a 100 degree day at 100% humidity and a standard pressure, you would get 88% hp, the dyno correction factor would be 1.126.
 If you are using say 10% nitro normally on a standard day, you would multiply 10% by 1.126 ,this would give you 1.12 %increase in nitro x 3 would total 3.36% increase to compensate..or you would run 13.36% nitro fuel.
A quick way to figure this,if you are adding nitro at the field would be 3.36x128=4.3 ounces of nitro added to a gallon of your fuel
Depending on your particular setup you may need to use a multiplying number of 3 (and I think 3 would be real close)  or it could be as much 4.5, or as low as 2.5, these numbers would get you very close.
 I don't think there would be one universal number that would work for everyones setup, and ever percentage of stock size nitro that we all use, but I don't think the range would be very far off from another persons,, but you could very easily use it and develop  your own multiplier number..ie find your factor..wether it be 2.0, 2.5,3.0,4.5 or what number works for your setup
You would need to buy one of the hand held weather stations that I have used, they would give you all the info you needed at the flying site.
They are available online
« Last Edit: August 01, 2009, 11:02:21 AM by RandySmith »
Online RandySmith
« Reply #8 on: August 01, 2009, 11:12:06 AM »
http://www.weathershack.com/kestrel/2500.html
The Kestral 2500 would be a good hand held for calculating at the field
I think it may also, that you can base the calculation off of just the density altitude alone.
I have used this unit and it is a very good one
« Reply #9 on: August 02, 2009, 12:50:04 AM »
   The density altitude correction should be pretty close. But I have had excellent luck just adjusting the nitro content until I get the same run time for the same volume of fuel.
« Reply #10 on: August 02, 2009, 04:12:46 AM »
Thank you, Randy and Brett
Brett, when using the "same run time" method does this mean same T/O RPM or same needle setting?
Peter Germann
Online RandySmith
« Reply #11 on: August 02, 2009, 11:53:08 AM »
Hi Peter
You can add nitro until you get the same run time as Brett suggested ,and also look for the same performance, the RPMs will NOT necessarily be the same.
Many times you will notice that you will have to change the needle until the engine "sounds" the same .
But if you get the amount of nitro by trial and error method, you could then back it up into a formula to use the density altitude method or the program you asked me about.
I use the method Brett suggested many times, For me, going up 3000ft in density altitude I have to about double my nitro..ie  7.5% I go to 15%, 5% I go to 10%. This is very easy to do the math for any density altitude.
This will get you very close but there are other factors that will affect the planes, even the surface you are flying off of will have an effect on the plane, example is black top vs. grass
I carry my fuel in a box that holds 4 gallon cans, I take normally 5% and 10%, if the contest is somewhere in between I use the 2 mixed to get 7.5%, If I am going to a really hot or high place I take along a gallon of 15 or 20%
« Reply #12 on: August 02, 2009, 01:12:21 PM »
   Whatever setting it takes to get the same performance. If the absolute air temperature is the same, on my engine, the needle winds up in about the same place.
« Reply #13 on: August 02, 2009, 01:22:00 PM »
   And of course, you can mix the fuel in the sryinge. Pull out 2.5 oz of 10%, 2.5 oz of 15 into the same syringe, and you have 12.5 percent with no pouring or mixing. I was doing that at the NATs this year at times. It's a lot safer in AMA than it is in FAI, since you have the extra minute at the end.
Online RandySmith
« Reply #14 on: August 02, 2009, 02:02:17 PM »
Peter
If you are trying to get a formula that works, you may want to try this, use a factor of 125% per each 1000 ft of density altitude increase:
IE..you use 10% nitro at your normal field and setup it is 1000 ft density altitude, you are flying where the density altitude is 3500 ft
so you would increase your fuels nitro by 25% for each 1000 .
This would be 10% nitro =2.5% increase per 1000 ft x 2.5 (the 2500 ft increase)=6.25 % increase in nitro
You may see this works right or you may have to use 130% or even 120% for your multiplier, but it should not be any problem to find your number.
« Reply #15 on: August 04, 2009, 09:04:28 AM »
Good Morning, Randy
its not so much a formula but an easy to carry chart showing the change of nitro content required to  compensate density altitude. I do remember how to find density altitude from std. temp deviation and QNH. From there, using the engine tuner website, rel. power can be defined. Is it too simple to assume that all that remains to be done then is adding enough nitro to compensate the loss?
Trying to quantify „enough“ I was today running an older type OS .29 with three different fuels while measuring peak RPM. From  the rpm gain observed I have then calculated the relative power, assuming that a specific increase of prop RPM requires a power change by the cube. (i.e. to double RPM of a propeller it takes 8 times the power) Nitro was 99% and oil 15% KL-200 + 5% castor. Prop was 9 x 6 2bl.
10% Nitro, 11'600 rpm, 100% rel. power
12.5% Nitro, 11'750 rpm, 103% rel. power
15% Nitro, 11'850 rpm, 107% rel. power
Does this mean that if, when flying 10%,  I suffer a 3% power loss due to density altitude change, I can compensate the loss by going from 10 to 12.5% nitro, thus incerasuing power by 3%?
Peter Germann
« Reply #16 on: August 04, 2009, 10:01:54 AM »
Does all lthis take into consideration humidity?  When flying F2C we had to keep adjusting for humidity in some areas.  The one I remember most was Buder Park in St Louis.  Round by round there were humidity changes.  DOC Holliday
Offline don Burke
« Reply #17 on: August 04, 2009, 10:46:11 AM »
Humidity does affect air density which is what you are adjusting for with altitude changes.  Most of the savvy F2C teams use air density as an indicator.
don Burke AMA 843
Menifee, CA
Online RandySmith
« Reply #18 on: August 04, 2009, 12:26:23 PM »
Good Morning, Randy
Hi Peter
Your numbers may work for you or they may not, I do not believe you will find a formula that works for every plane and every engine that any pilot has.
I do believe that if you just concentrate on air density and have an air density meter,such as the one I suggested, then you can find a formula that will work for a given plane.
Even is it does not work perfecdt every time, it will get you very close. I would use my fiqures of double the nitro for every 3000 ft, and not worry about entering complex calculations into a computer while at the field. You will be able to make a simple chart with the density altitude reading once you nail down the numbers that works for your system.
 Remember the engine is NOT the only thing affected, the wing lift and propellor effiencey are affected as well as power out put of the motor.
You have shown you get 7% increase in power for 150% increase in nitro, this will be a tool to setup a chart, but you will have to test it on your plane and adjust the numbers to suit your setup.
I think you will find that this trial and error method will not be hard to do and it is the easiest way to accomplish what yopu want to do.
Online RandySmith
« Reply #19 on: August 04, 2009, 12:39:11 PM »
Hi Doc
The density altitude includes the dew point temp.
http://www.divemaker.com/trajectory/da.php
The above is a wing loading convertor for density altitude
And below is a simple density altitude chart form NOAA, I can include many other site that complex number calculations for this but I think this shows how we are affected
http://www.srh.noaa.gov/elp/wxcalc/densityaltitude.shtml
Offline Kim Mortimore
« Reply #20 on: August 11, 2009, 02:35:14 PM »
So reading between the lines, I take it that if you were to put up one flight using 10% fuel, and then another a short time later using 12.5% fuel, same prop, needle setting and fuel volume, your run time would go....up?  If so, is there simple math to estimate how much?
If you're flying at a contest where it's, say, 75 degrees in the morning and 90 degrees midafternoon, would you recommend starting the day with less nitro and adding more as the day grows hotter?  Does the increase in temperature tend to offset any change in run time due to increased nitro %?
Kim Mortimore
Kim Mortimore
Santa Clara, CA
« Reply #21 on: August 11, 2009, 08:15:49 PM »
    The flight time would go down - it takes more 12.5% to get through a flight than 10%, because to get the same power you have to run the engine richer.
     Depends on what the humidity does. Most of the time, the dew point stays the same throughout the day, so the morning might be 60% and 75 degrees, and later you have 30% and 95 degrees. Most of the time I figure out what nitro to run for a particular site, and figure I can adjust the needle to compensate. So, when I go from here to Muncie, I switch from 10 to 15 and get about the same. The variation from day to day once I am in Muncie is usually close enough that I don't need to change anything, and here, I just always run 10% and adjust the variations with the needle. If something drastic happens, then maybe it's a different story - David and I both had to go back to 10% at the 2007 Team Trials when we both started having the engine charge here and there - but mostly it stays the same.
« Last Edit: June 15, 2011, 10:39:52 PM by Brett Buck »
