Still trying to sort out my Stalker 51 RE. It is burning 1.2 oz per min (SIG 10-10-10) and 12-5 Zinger wood prop. One extra head shim. The run isn't steady throughout, but hoping that a bit more time on the engine will tame it. So far, about 15 min run on the test stand and two flights.
Hi Floyd, I'm sorry you are having a problem with your .51. Most of us agree that it's probably the best of the bunch, but you're having a few problems. Can I make a few suggestions?
First Stalkers "come in" with running. They settle into a stable, repeatable run. You know when it's happened when the fuel usage settles, and the engine behaves.
You might be experiencing problems because it's not yet broken in.
Having said that, I suspect something else might be the problem.
We here in America seem to want to run Nitro and have 50% of our oil being Castor.
Most of the guys who relate problems fall into this description.
So, here's the formula that I and Gordy use with this same engine.
0% nitro. That means FAI fuel.
There's no need for more than 20% oil. I use 18%, Gordy uses 20%. No more than 5% of that oil is castor.
I'm not afraid to go with all syn oil, but bow to a little castor, "just in case." I'm ordering a new batch of fuel that is 0% nitro,14% synthetic, 4% castor.
I am not a fan of Zinger props, I consider them a great prop kit. There are a lot of better props to use. I personally have used APC and Evo props. I like the Evo 12 X 6 for the .51. Gordy uses a CF 3 blade 11.5 X 5.5. I launch at 7800 rpm, gordy launches a bit higher.
I'm using 95 cc's of fuel, (about 3 1/4 oz's) Gordy uses about the same amount, for the pattern.
These engines were designed to run with FAI fuel, and mostly synthetic oil. When we try and run them differently, we have to make a lot of changes. Consider putting the engine back to stock, remove that extra head gasket, and see how it runs for you before trying to change the run over to our nitro rich style?
One of my friends was trying to get his new Stalker to run right. He's very knowlegable about our toys, but he was having problems. After he decided to try what I'm saying here, his problems went away, and all who have seen and heard his engine runs have come away impressed.
Try it, if you don't like it, I can think of several folks who would make you an offer for your engine.
Edit; Steve made his post while I was typing mine. Kieth's engine setups and runs are different from mine. It just shows the range this engine can operate in when it's set up right. Kieth launches at over 10K in a dead 4 stroke. with his flatter pitch prop. It breaks where it should and runs smooth. I'm not sure, but I think hes either running FAI fuel, or very low nitro. Perhaps he'll chime in.
