  • June 18, 2025, 04:45:42 AM
Author Topic: OS .20FP Needle Valve  (Read 1991 times)
« on: October 09, 2018, 07:49:35 PM »
What’s the part number?  I’m at a club meeting and too busy eating to look it up.
Offline Dane Martin
  • heli pilot BHOR
Re: OS .20FP Needle Valve
« Reply #1 on: October 09, 2018, 08:14:27 PM »
Os part number is 22311000
Offline Gary Dowler
« Reply #2 on: October 10, 2018, 06:05:00 PM »
Howard, let me know if you locate a stash of these someplace......
Gary
« Reply #3 on: October 11, 2018, 03:24:00 PM »
One other way to get a good needle valve setting is to switch to a Fora F2D needle valve.  It requires some simple mods to the case and a change in venturi size.  The NVA body is 4mm, and the case has to be reamed out to fit and counter bored a bit(can be done by hand if need be) for length.  The result will give a needle setting with about 1 full turn between 4 cycling and 2 cycling.  Seal the needle with a short piece of silicon fuel line.
« Reply #4 on: October 11, 2018, 08:05:57 PM »
or you could put a  PA  NVA  in it  like  100s  have  done
« Reply #5 on: October 12, 2018, 10:39:37 AM »
Thanks, folks.
Offline Fredvon4
  • Central Texas
« Reply #6 on: October 12, 2018, 02:05:46 PM »
I have one
21181902.....1A,15
And 3 of the smaller
21081909.....10R/C
Fred von Gortler IV
« Reply #7 on: October 12, 2018, 02:21:38 PM »
So -- Really Slow Combat?  Your next stunt ride will be a JU-52 with slime power?  You're giving up on flapped stunters and building a Skyray?
« Reply #8 on: October 13, 2018, 04:13:58 PM »
Howard was axing for Steve Holt, who may not be a SH member. I read on here that Tower is out of the .20FP NV Assy. And I'm wondering if Fred's stock is front or remote type? I have a .10FP RNV assy and another that I think is a .35/.40FP RNV, and they're available.  y1 Steve
Offline Fredvon4
  • Central Texas
« Reply #9 on: October 14, 2018, 03:21:07 PM »
Both mine are Remotes  and like a lot of Tower OS parts are unobtainable...Permanently out of stock
Only real game in town these days are the cottage guys
Lee
RSM
Doug Galbraith
E-bay...Shttrman
Hell a few years back I bid on a 25 engine lot...mostly junk.... won for $38 + 10 bucks shipping....
Heads, NVAs, Back plates, about 50% I stripped for my parts drawer and pitched the horribly gunked up and seized engine.... not wort my trouble to crock pot and refurbish........really Virginia  $1.92 per engine
In the lot I got 11 well preserved and working engines... Cox .049s, OS 30 stunts, Enya 4224s,  and three fox . 35s
Fred von Gortler IV
