  • July 14, 2025, 12:47:20 AM
Author Topic: Stalker big block, .81RE  (Read 1361 times)
Offline John Miller
« on: January 03, 2007, 02:34:06 PM »
Mainly, this is posted to get Walter Hicks to share any additional info on his big block Stalker. Hey Walt, mine just came in the mail. So what's happenin' with yours????
Re: Stalker big block, .81RE
« Reply #1 on: January 03, 2007, 03:57:23 PM »
John,
What's it weigh? Do you have a kayak paddle to use as a prop?   :##
Walter Hicks
« Reply #2 on: January 03, 2007, 07:54:49 PM »
    Stalker .81 RE is 13.5 oz. RE muffler 1.2 oz. I have been using Omega FAI fuel with one oz of Aero 1 and 2 oz of Klotz for break in purposes.It has been bench run only with a variety of props. The latest being Gator 14x4 two blade
repitched to 6". Ran a 8200 in a nice four stroke. Bolly 14x6  slightly less four stroke rpm. I will be testing it in my big Laser which required nose surgery to fit the Stalker . I got some paint on it today and should be testing the Big
Stalker in it by months end . I will  also try to shoehorn it in the ARF Strega. This will be a good comparison with my RO Jett .76 Se with muffler in the Strega. I also have been running my new Stalker Long Stroke .61 I absolutely love it!!!.
Offline John Miller
« Reply #3 on: January 03, 2007, 08:15:16 PM »
Thanks Walter, that gives me a starting point with the brute. I also picked up the light weight long stroke too. I probably won't be running any fuel through them until a bit further into the spring.
I'm thinking about finishing my Tony for the BIG BLOCK.
Randy, you've got to see one of these things. A little over 14 1/2 ounces with the muffler.
Offline Jim Morris
« Reply #4 on: January 05, 2007, 12:30:07 PM »
Hi guys, just in case nobody knew. Stalker now has a 66RE which is available now. The 76 is not yet.
