  • July 07, 2025, 05:29:42 PM
Author Topic: ST60V ID  (Read 1761 times)
Offline Gordon Tarbell
ST60V ID
« on: June 20, 2010, 10:44:20 AM »
Going through my engine draws(yes I have more than one) I started pulling out my examples of ST60's . One of them that I picked up along the way looks brand new/unrun , it has a blue anodized venturi (apprx. .200") with the NV acting as the retaining device . I removed the head and back plate for a look see. The head looks stock like some older ones I have( deep hemi chamber with a squish band apprx .150"wide. It has a gold colored plug (Idle bar type). The crank looks like it has more counter weight than the others and the discharge end of the center hole is hand radiused. Stroke measures .860" and bore is .946" or so. On the intake side of the engine, two round holes are in the skirt of the piston that match with two holes in the sleeve below the normal square holes for intake. I have not put a degree wheel and dial indicator on engine to map out port and crank timing but the eyeball says a slight delay on exh opening and a slight advance on closeing of the exh might be present. This thing looks like it has never run the crank has a slight gold irridite look to it .  Any Idea who might have done these mods, would like to know so I could contact for running info and what to expect performance wise. Thanx in advance.
« Last Edit: July 03, 2010, 02:54:48 PM by gordon tarbell »
Gordon Tarbell AMA 15019
Re: ST60V ID
« Reply #1 on: July 03, 2010, 11:33:27 PM »
I have finally added the pictures of this engine showing the extra holes in the sleeve and matching holes in the piston. I am thinking this is some form of PDP (perry directional port). the outlet of the hole in the crank is chamfered and the inlet hole in the crank (just below the venturi area) has been slightly massaged also. I hope to find out who might do these mods and what they are supposed to gain or change. I plan on putting it on the test stand next week end using 10 - 22 (50/50 syn,castor). I thought the blue anodized venturi might be a signiture of the builder also.
Re: ST60V ID
« Reply #2 on: July 04, 2010, 12:24:23 AM »
Good job on the pictures, Gordon! You did all the resizing and compression yourself? Or was it the 13 year old kid down the street?  LL~
Nothing engraved on the case or head? Many tuners do that. GMA vibro-engraved "GMA" on the side of the head. I have a Big Jim ST .60, and it has "L" on one side of the bypass and "J" on the other (LJ for "Large Jim"), and LJ on the front side of the head. I have a few Tom Lay engines, and they have "T&L" engraved on one lug and a serial number on the other. I believe Randy engraves something on his reworks; dunno about others, but it's likely. I don't know who else might have done ST .60bb reworks, back in the day.
Regarding the holes in the liner and piston...lots of older engines had similar holes. I think McCoy .60's, and maybe OS MAX III's. But the holes were in the piston skirt, certainly not above the wristpin bosses. So, that looks maybe stock, or maybe not, to me. It should do a fair job of cooling the piston crown from underside, but as for power, probably not.  I am pretty sure Perry Ports are not like that. I have an engine with PP's, and that is not even close to similar. I'll have to ponder which engine that would be, and then find it. With PP's, you can look in the exhaust and see some extra bypass sorta things. These on your .60, you wouldn't be able to see from the open exhaust stack.  H^^  Steve
Re: ST60V ID
« Reply #3 on: July 04, 2010, 07:57:28 AM »
The only distinguishing feature on the exterior is the blue venturi(.200"ID& two small saw marks on the rear of the head were the fins end into the head . All the grinding done inside appears to be done by  hand (done well ) In a previous life I used to do alot of cyl. head port work and am somewhat familiar with a good hand at grind work. I was going to make several more venturis for it still utilizing the off to the side style NV.  I will make them in increments of .005" starting at .180" going up to the .200" currently installed. That should give me some tunning lattitude.
Re: ST60V ID
« Reply #4 on: July 04, 2010, 08:15:40 PM »
Since you didn't mention the head having the conical head fins (like my LJ ST .60), I'm sure it's not one of the last ones. Those did have Perry Ports from the factory. I'm not sure if that's a good thing or not, but Colin Pickard did a test report on one in SN a long time ago, and said it gave very good power and fuel economy for a ST .60. Maybe because of the PP's. But I also read that some tuners plugged the PP's with JB Weld. I think he ref'd to it as a "K" model, but I don't know why. Those were made about the time World Engines was going Tango Union and ST's were soon to be sold as Como's by Indy R/C.  D>K Steve
Re: ST60V ID
« Reply #5 on: July 05, 2010, 09:48:39 AM »
I will reassemble this thing and test it. I plan on trying it with two different heads. One head looks like all the other stock small hemi style with wide squish band, the other looks like a nearly full bore dia. hemi cut head with a baffle clearance slot,very little squish if any. I guess this might be similar to what people call the Big Jim hemi style. I am going to use a 10/22 mix of fuel (50-50 on syn- cas oil mix). Not sure what prop to use after break in but will use a 10-4 for initial run in to keep load down on fresh engine.  Was thinking of useing a 12-6 for testing there after. If someone has more knowledge please feel free to chim in to shorten my learning curve and prevent reinvention of the wheel.
Re: ST60V ID
« Reply #6 on: July 05, 2010, 11:38:13 AM »
Hi Gordon
Don't use a 10 x 4 for breakin, use a 12 x 4 or 12 x 5 the ST doesn't like to rev as high as a 10 x 4 will, and at least 2 people have done rod damage with a 10 x 4 at breakin, The ST 60 you have runs very well on a 13 x 6 or 13 x 5
 by the way that is a perforated piston porting arrangment on the motor, I have done that many times with engines
Re: ST60V ID
« Reply #7 on: July 05, 2010, 01:33:10 PM »
Thank you Randy, I will use the 12-4 as you suggested.  Sure hope One day you offer the 65RE again or maybe a new and improved version.
