  • June 19, 2025, 11:32:42 AM
Author Topic: ST/51 socket bolts  (Read 2203 times)
ST/51 socket bolts
« on: May 05, 2006, 08:15:15 PM »
Randy or any one who knows,what size is the allen wrench that fits the head socket bolts on the ST/51. I can;t believe I don't have one to fit. It might be metric. I measured the opening across the flats and it is around.100 ths.
Ed Ruane
Eric Viglione
Re: ST/51 socket bolts
« Reply #1 on: May 05, 2006, 09:14:06 PM »
Hi Eddy! I know the OS FP's use metric 2.5mm and it seems the ST G51's use metric also, but the larger 3.5mm see below.
Eric V.
According to the Tower Parts page:
 This is a Screw Set for the Supertigre:
               GS40, GS45, G51 (ring and ABC) and G500 Engines.
INCLUDES: Four 3.5 x 15mm Screws (head bolts)
          Four 3 x 6mm Screws (backplate)
And the full link to the G51 C/L parts page:
http://www2.towerhobbies.com/cgi-bin/wti0005p?&I=SUPG0829&P=PU
« Reply #2 on: May 05, 2006, 09:24:16 PM »
Hi Eric  I have the bolts and some metric wrenches but not the one for this motor. I need to know what size wrench not bolt. I am going to fly the new plane tomarrow if it doesn't rain. I got the new muffler and the 13.4 props. I also got some gaskets and wanted to lower the compression. A 45 oz plane with a .51 in it makes for a powerfull combination.
Eric Viglione
« Reply #3 on: May 06, 2006, 02:42:41 AM »
Sorry Ed, you are right, that is the bolt size. Well, at least you know it's smaller than 3.5mm! The OS FP use a 3mm bolt, and it takes a 2.5mm wrench, the same logic would say a 3.5mm bolt may use a 3mm wrench, but since when did Supertigre do anything standard, right? hah!
I'm surprised someone who knows the answer hasn't chimed in here.
I can be a bit of a butcher sometimes, and would probably just take a file to a worn out old oversize wrench until it fit... %^
EricV
Offline L0U CRANE
« Reply #4 on: May 06, 2006, 03:36:45 PM »
Ed,
If all else fails, you can do what I've been doing for a few years...
Find an ACE, Lowes, Home D or other major hardware store that sells US and Metric keys. Bring along the engine, and try what they have until you find one that fits right.
The local Ace guys are used to me by now; you might have to break in some newbies...
Now, if THAT fails, there are specialty fastener shops around. If none local, S&H is guaranteed to be more than the items ordered... If they can even match from the bolt specs.
BTW, the key that came in the box with mine (China-made) measured about 2.9mm across the flats. A 3/32" key is too small; that's 2.4mm in metric.
Someplace to start, anyway.
\BEST\LOU
« Reply #5 on: May 06, 2006, 06:18:25 PM »
Lou  & Eric   I stopped and bought a set of metrics on the way back from the field.The 2.5 works but it is not the tight fit I like.  I think the bolts are Junky. Not straight but they have a slight taper.The wrench I know have will let me get the head off and add a gasket. The motor is running like it is over compressed.The plane is a Humongous and it flys very well. It is only 46 ounces. I have some BY&O 13/4's that I am going to trim down to let the motor run fast but fall back into a fast four cycle in level flight.
« Reply #6 on: May 06, 2006, 08:20:52 PM »
I've run the Tigre 51 on a Tutor II and also on a combat style foamy wing profile designed by Doc Passen.  In both cases the planes were large but very light.  In both cases the 51 was not too much power.   Both planes used the exact same setup, Rev-Up 12-5 (the bulk gov't contract version without any printing on the blades), and a K&B long idle bar plug, with Sig 5% or 10% nitro Champion fuel.  The fine needle and broad torque curve of the Tigre allow for needle adjustment to dial in the power wherever it feels good.  I've never felt the need to de-tune it.
