Engine basics => Engine set up tips => Topic started by: Gordon Tarbell on May 02, 2006, 05:37:47 PM
Title: ST V60
Post by: Gordon Tarbell on May 02, 2006, 05:37:47 PM
Now that the st V60 is old hat compared to the new PA and RO Jett engines . Are there some standard engine setups for the stV60 to be used in a 700 sqin. stunter? Such as venturi size ,target rpm,Prop dia. pitch  best nitro % and oil content and type.etc. I can't go with a modern eng yet so I would like to run these two that I have. One will go into a Strega and the other probably a china clipper. Thanx for any good input as I would not want to waste time reinventing the wheel.
Title: Re: ST V60
Post by: RandySmith on May 02, 2006, 08:16:14 PM
Hi
I setup over 300 of the  ST 60s  for  people, this the standard setup:
The ST 60 wworks very well with a #14 venturi , 13 x 6 or  13 x 5.5  prop in 2 blade  or  12 x 6.5n  3 blade
5% nitro in cool months  going to 10% in hotter  summer months.
Launch where the motor is  just cackling in and out of a 2 cycle, the ST 60 will drop to a fast 4 cycle when it goes airborne.
There are other setups but   this has proven to be a very good one.
Regards
Title: Re: ST V60
Post by: Gordon Tarbell on May 02, 2006, 10:12:11 PM
Thanks Randy , that is what I was looking for. Is this #14 venturi one of your propriatary venturis or is there a generic size that this coresponds to?  Would an Enya #3 glow plug be a good choice? Is the PA 65 RE and SE a direct drop in replacement with similar weight and a bit more grunt.
Title: Re: ST V60
Post by: Bob Reeves on May 03, 2006, 03:33:01 AM
Not Randy and don't claim to know as much, but believe the #14 refers to the drill size of the hole in the venturi. Am sure someone will correct me if this isn't correct.
Title: Re: ST V60
Post by: RandySmith on May 03, 2006, 11:22:41 AM
Hi
Yes the true venturie size is a number 14 precision drill size. if you use  restrictors on the engine (tube with a spray bar going thru it) you would use a .290
The Enya #3 will work well, as  will the Glo Devil 300, T Bolt RC long, and several others, you just need a hot plug.
The PA 61 and 65s are slighlty smaller but have the  same mount size so they will drop in where the  ST60 came out. They do put out much more power, and a lot smoother.
regards
Title: Re: ST V60
Post by: Gordon Tarbell on May 03, 2006, 05:25:18 PM
Thank you for the info randy I look forward to getting these two old dogs running.
