  • June 15, 2025, 10:56:13 PM
Author Topic: ST V60 Muffler recomendations  (Read 3909 times)
Offline Carl Cisneros
« on: December 26, 2023, 06:06:26 AM »
Folks;
Got a newish ST V60 engine ( I did replace the bearings with a set from Boca Bearing),
and am wondering what is being used for a good muffler.
It is required to be the strap type mounting. (no mounting ears on the engine)
Thanks in advance.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Craig Beswick
Re: ST V60 Muffler recomendations
« Reply #1 on: December 26, 2023, 10:57:27 AM »
Stan Frady, on FB, could probably make you a tongue muffler for it.
Craig
AUS 87123
"The Ninja"
« Reply #2 on: December 27, 2023, 01:59:01 PM »
checked with Tom and he does not do them.
will keep searching
Control Line RB
Offline Manuel Cortes
« Reply #3 on: December 27, 2023, 10:26:15 PM »
Hi all!
In my opinion one of the best solutions is to find a original Merco muffler, perfect fit and light weight. Remove the internal baffles and tou are ready to go!! Some decades ago this setup was used in competition, so.....
Kind regards form Spain and Happy 2024!!
Manuel.
« Reply #4 on: December 28, 2023, 01:38:17 AM »
will keep searching
Was this in response to my suggestion? Tom?
If you want a tongue muffler send me a PM and I will organise contact details
AUS 87123
"The Ninja"
« Reply #5 on: December 28, 2023, 11:31:34 AM »
Carl,
I got a message back from Stan Frady on FB, he said he has tongue mufflers for the tab-less ST 60. He is in the PAMPA group on FB.
Best,   DennisT
« Reply #6 on: December 29, 2023, 05:59:52 AM »
thanks guys/
I actually did find a muffler for the engine.
thanks for your help
Carl
Control Line RB
« Reply #7 on: December 29, 2023, 02:44:36 PM »
   Some of these versions of the St.60 had a hole in a boss that is in the middle of the exhaust. Tom Lay used to make an adapter for that engine that attached to the exhaust by that screw in the middle and fit snug around the perimeter. it had muffler ears located on the adapter that matched typical ST.60, .51 and .46 dimensions. I had Jim Lee make a few spares for me. You might check with Jim to see if he still has his noes and drawings for that. When I use mine, I use the screw as usual but apply some JB-Weld around the edges to stabilize and re-enforce the joint.
 HAPPY NEW YEAR!!
« Reply #8 on: January 01, 2024, 08:53:11 PM »
Some Double Star mufflers fit on the early ST 60 , firmly . May need a light scrape in the flange . ( one do one dont )
WITH the piston at TDC , on the 60 , you look at the outer lower edges . If theres a six foot gap there , the tounge Muffler gives blowback , and they run better
( more Grunt etc ) on a TUBE MUFFLER  std theyre 3/4 or 7/8 bore , maybe four or  five inch chamber , 3/8 outlet tube . the sausage ST one is pretty similar .
Ya wanna look after it . https://stunthanger.com/smf/engine-set-up-tips/tom-lay-super-tigre-v60-break-in/msg612285/#msg612285
Likeso .
