Ditto ;
So many things are climatic , site alt etc etc . Someone can have one ' spot on ' where a identical one can be a dog .
Bit like that with cars and motorcycles , Some Peoples arte dogs and have you ever noticed mine are much faster .
GOOD OIL so ya dont tear the guts out of them . After Run oil or get rid of the corrosive nitro residue if not flying again the next day .
Having ' suffered a Magnum GP FP 40 Clone , and a S/H FP 40 , ive another ' in the mail - on its way .
Seems some say the BIG R/C muffler , particularly if your into profiles , isnt a bad idea . One can cut half thru the bolts at the join face ,
if the earth hasnt stopped getting in the way of your aeroplane. & carry a few spares .& spare props .
Something fairly solid to start with isnt to b ad an idea, till youve got things figured out a way .
Undercarrages on profiles can absorb a lot of pounishment , and timber props dont take fingers off like some others .
If you start getting realy keen you could whittle out the FP head ( Putting a custom one on my Ball Race FSR 40 Turned it into a steady 4 stroke set up . maybe.
You cant trust these FSRs Either .
And bunging the boost port in the 40s is no big deal , a 1/4 x 1/8 balsa 1/2 long about covers it , with a drop of epoxie to cure - if your starting to loose sleep .
The STIFF 11 x 4 Tornado / Grish props work well on em , if you find a bag at 4 2 Ea .
Most OSes will run fine without nitro , too . Wasnt Available where I was till the Drag Racing took hold & they satarted importing it .
So you can plough your own furrow , which isnt the same as digging a hole & burying yourself .
Theyve both got plenty of power . My Stock FP pulled the 65 Oz 68 Span ( only abvout 600 sq in ) as well as a ST 46 , on a 12 x 4 Tornado, and chip / tounge muffler .
Not sure how the old Iron Piston / Liners like having the heat held in there tho , was that or corrosion on the crank web going thru that loosened it of in the bore .
Early FPs are IRON , unhardened ?? steel liner , so need good castor . Old Days people would bake OS liner & piston three times , ( 1 Hr, cool , repeat, x 3 )
then lap in with toothpaste , according to a few F M Articles , stabilises & Hardens them . Later round case FPs might be ABC , if its got ' ABC ' on the BOX .
Let us know how you go . Beats watching the Television.
