  • July 19, 2025, 03:25:08 AM
Author Topic: ST G51, Italian Case  (Read 2413 times)
Offline David Felinczak
  • Always Remember
« on: June 26, 2015, 12:36:27 PM »
Randy,
This is one of your stunt modified engines I bought from you a few years ago and is still running great with plenty of power.
I am building a Strega and would like to use this motor in the Strega. My other option is a stunt modified Saito FA72 CL motor.
What do you recommend?
Thank you for your assistance.🇺🇸
David Felinczak
865337
Re: ST G51, Italian Case
« Reply #1 on: June 26, 2015, 10:24:41 PM »
Randy,
Hi David
If it is built light the 51 will pull it, if it is too be a little on the heavy side and you only have just the 2 eninges  I would use the 72
« Reply #2 on: June 26, 2015, 11:23:17 PM »
Hi David
  Ditto. The Strega needs all the power you can throw at it. I wouldn't even consider an ST51.
  • Always Remember
« Reply #3 on: June 27, 2015, 10:18:16 AM »
The FA72 CL version was modified by Bob Reeves. Added RPM adjust screw in carb/Venturi to adjust RPM.
Is there any problem with engine performance when the Saito is mounted inverted?
I also have a new original VECO .61 and a new K&B .60 Gold Head that are options.
Brett,
Thank you for your input.
David Felinczak
865337
« Reply #4 on: June 28, 2015, 06:29:02 PM »
Brett,
The ST 51 will put out more power than the Veco61 , you will need to decide , I would think about how much it will weigh, and be realistic about that, if it is to be on the heavy side it will need a lot of power, I would use the Saito  over the60 Gold Head, which maybe the second most powerful motor
  • Always Remember
Re: ST G51, Italian Case (revised)
« Reply #5 on: June 28, 2015, 11:16:53 PM »
Randy,
I went through my motors and found a new Enya .60 Series III CL ringed motor (new in box)!
Your thoughts for the Strega.
I remember a discussion I had with Bob Reeves who flew Saitos exclusively and he told me that
in his experience the Saitos ran best mounted sideways like a profile application.
In addition, there is not much room in the Strega's engine compartment to accommodate the Saito.
David Felinczak
865337
« Reply #6 on: June 29, 2015, 09:02:15 AM »
Randy,
Hi David
You could use the Enya 60, the Enya is a powerful 60 ,people have use the ST60 before in that plane, the Enya will put out ample power, but whatever you use  keep the plane light straight and stiff.
  • Always Remember
« Reply #7 on: June 29, 2015, 09:29:58 AM »
Randy,
Thank you for your help. I will use the Enya.
Do you work on ST .60's? I have one of the older engines with the clamp on muffler and a short, gray Venturi.
Bought the motor used and I need it gone over before I install. I got it for the Hawker Hunter my ex and my kids gave me for Christmas a few years ago!
Let me know.
David Felinczak
865337
« Reply #8 on: June 29, 2015, 09:37:12 AM »
Randy,
Let me know.
Yes  I have setup almost 600 of the  ST60s , so I am well experienced with them
  • Always Remember
« Reply #9 on: June 29, 2015, 11:44:26 AM »
What is your procedure for getting you the motor, payment etc?
Do you have a flat rate, base charge
I can send you a check, money order with the motor or PayPal.
Whatever you prefer.
I will need ship to info also.
Thx
David
David Felinczak
865337
« Reply #10 on: June 29, 2015, 11:48:09 AM »
Thx
David
if the motor is used I will need to see it before i know what it would need, basic cost is 75.00  for B&B setup, plus bad parts that need replcing
I take Visa  Master Card  COD   Cash
Randy  Smith
1047 Sawgrass  Ct.  S.W.
Lilburn , Ga 30047
678 407 9376
  • Always Remember
« Reply #11 on: June 29, 2015, 03:18:46 PM »
I will ship this week with a initial check for $75.00.
I will cover any additional cost with Master Card.
Will forward tracking # when motor ships.
Thank you
David
David Felinczak
865337
