Forces on the fuel in a tank are centripetal and Earth's gravity. Force vectors at 90 Dgrs are independent from each other. On our flying circle, the only time when the vectors are independent is when we are flying on a level path. Fuel stays at the back of the tank when we climb even if we are "stopped" due to gravity (9.8 ms(sq). When we dive, we are accelerating to counteract the Earth's gravity and that keeps the fuel also at the rear. If we don't accelerate or at least equate 9.8 ms(sq), the fuel will fall away from the pick up tube. The best tanks for the stunt pattern are the homemade tanks where the wedge is tapered/angled out towards the rear thereby using the centripetal forces to keep the fuel at the rear.
In R/C pattern, 3D or any aircraft where the transfer of weight by the fuel is critical for the performance, the tank is mounted near the center spar of the wing/CG and a pump or pumped engine is installed.
