  • June 16, 2025, 01:39:41 PM
Author Topic: Stuck remote needle in OS LA .46?  (Read 2369 times)
Offline frank mccune
« on: June 09, 2020, 10:19:38 AM »
     Hello:
     Yesterday, I noticed that I could no longer turn the needle on the remote nva of my OS LA .46.  I removed it from the airplane and had to use a vise and pliers to remove needle.  It appears that the rubber seal had become swollen to a point where it would not turn easily.  I tried it in two other bodies and it was evident the it was indeed the rubber seal was too large.  I replaced with another needle and all was well.
     Has anybody else enjoyed the joy of having this happen? Lol Or is it my bad karma that continues to haunt me? Lol
     Comments/remarks?
        Be well,
        Frank McCune
Re: Stuck remote needle in OS LA .46?
« Reply #1 on: June 09, 2020, 10:20:58 AM »
I haven't had that happen -- if you didn't bung up the needle valve too much taking it apart you may be able to replace the O ring and restore function.
« Reply #2 on: June 09, 2020, 01:34:48 PM »
     Hi Tim:
      I got lucky and replaced the “O” ring and all is well again.  The original ring was swollen and was much too large to be able to be moved.
     Thanks for the reply.
     Frank
« Reply #3 on: June 11, 2020, 01:19:04 AM »
Frank,
That seems odd in normal usage.
Certain rubber materials swell on contact with the "wrong" chemicals. Notoriously, silicone rubber (orange colored) and kerosene. I would have expected the OS needle to have a nitrile (BUNA-N, or NBR) rubber seal, but do not have the spec.
Are you using any special additives in your fuel? Have you dunked the engine or NVA into a solvent-based cleaner?
McDivot
« Reply #4 on: June 11, 2020, 09:58:17 AM »
        Hi All:
        I have only used 5-11-11 fuel since I have owned it.  No oils on the parts.  It performed quite well up to this tlme.
          The rubber O ring had swollen to a point where the entire groove was filled to take a rectangular shape.  It was so tight that I was forced to use a vise and large pliers to turn the needle.  I will test it ASAP.
        Thanks for the replies,
        Frank McCune
« Reply #5 on: June 12, 2020, 12:57:51 PM »
     Hello Again:
      I thought that I had solved the problem of the sticking needle, but once again I was wrong.  I replaced the sealing O ring with a new one and all was well until the first tank of fuel went through the nva.  Once again, there was no way that the needle could be turned!  I even resorted to using pliers but they slipped rather than turn the needle.
       What to do now? The O ring that I replaced the original one with was made of neoprene.  Neoprene is said to be able to stand up well against glow fuel ie neoprene fuel line.  Is there a source of seals for the OS remote nva?  What else can be used?
        Comments/sSuggestions
         Tia,
          Frank McCune
« Reply #6 on: June 12, 2020, 03:46:02 PM »
     Hello Again:
   What brand of fuel is this?  I checked the engine from the test the other week, and, just like everyone else's, no problem. I used Powermaster 10% "Air" which is 9/9, but there have been no reported problems with GMA, either.
« Reply #7 on: June 12, 2020, 04:07:29 PM »
     Hello Brett:
     The fuel that I am using is my home brew of 7.5% nitro,11% castor oil, 11%synthetic oil, remainder alcohol.  I hope this helps.
     I will try another new nva to determine if it it is affected by the fuel.
     Be well,
     Frank McCune
« Reply #8 on: June 12, 2020, 04:38:11 PM »
     Hello Brett:
  It will be, you have plenty of evidence, don't ruin another one.
     You mean methanol, not alcohol, right?
« Reply #9 on: June 14, 2020, 06:49:48 PM »
    Hello Brett et.al.:
     Thanks for the replies.  Yes, I meant methanol.  I have used my fuel with these nva in the past with no problems.  I have no idea what is wrong! I am now testing an O ring made of silicone to determine if the silicone will suffice.  Will inform you all of the results.
     Be well
     Frank McCune
« Reply #10 on: June 14, 2020, 07:20:19 PM »
    Hello Brett et.al.:
  There is something else in that fuel making the o-ring swell up and stick, because conventional fuel components will not; there is no special magic that applies only to you. Something real is causing it and it's almost certainly in the fuel, because there should be nothing else around.
    This convinces me even more that there is some systemic problem you have. Before you do anything irreversible, *please* borrow or buy *conventional fuel from a major manufacturer*, like Powermaster 10% "GMA", "Air", or "Heli", or SIG Champion, and start using that. That will give you a baseline that is known to work and remove fuel - which is obviously either wrong or contaminated with something (acetone? coleman fuel? hydrazine? the "Free alcohol"? something else mentioned in these threads over the years?).
« Reply #11 on: June 14, 2020, 09:43:25 PM »
  In thinking about this, that O-ring is a seal against air leaking in. Crankcase vacuum is what draws fuel to the NVA and past the point where the needle regulates the flow, and then on up to the venturi, etc.  Any fuel would have to be under some kind of pressure, make it's way up the inside where the needle passes, and out onto the threaded external part of the NVA. The stock O-rings are probably a common Buna-N or nitril material. I sometimes recommend applying some grease to it to help with the seal if someone suspects that the O-ring is passing any air, and even that should not bother anything. In my industrial maintenance experience, it's usually something pretty caustic or "hot" chemically like an acid that gets to O-rings. Or your supply of O-rings or the place you get them has some REALLY cheap and defective ones.
« Reply #12 on: June 15, 2020, 10:29:45 AM »
  So, exposure to *air* caused it to swell up and jam?
    O-rings do not just swell up and jam exposed to either air, or normal commercial model fuel components. Therefore it was exposed to things not normally in model fuel. Given that this is home-brew fuel with unknown sources of the constituents, and it *consistently doesn't run properly* as suggested by innumerable previous threads, many of which contain discussions about obscure fuel additives, it could have lots of other things that DO cause o-rings to swell up, the most sensible way to eliminate the fuel as a source of problems is to get a commercial fuel of known quality.
   What does not make sense is to take a known-good part, and then start modifying it, changing materials, to try to "work around" whatever other problem is present, because there is absolutely nothing wrong with the part as it comes from the factory.  That's stacking a kludge on top of an existing problem. Of course, the next step is to "replace the crummy rear needle with a good ST spraybar", which stacks yet another change, now you have to also change the venturi, or the engine suddenly loses 20% of the power, and also induces the potential for more problems with the known "tuning fork effect".
    That's how these things spiral out of control. The fact that a presumably stock part, known to be good, is getting jammed up tells you beyond any reasonable doubt that there is something odd about the fuel, because that's the only thing this o-ring is exposed to that could conceivably cause it. That's a problem that needs to be fixed, forget anything else, before proceeding to the next step, because whatever it is might also be causing the systematic low power and odd run characteristics that Frank has been experiencing, well, forever.
   Of course, as always, it's just advice, no one is compelled to listen or act on it.
   The red flags don't wave any more wildly than this.
« Reply #13 on: June 15, 2020, 04:22:59 PM »
    Hello Brett et.al.:
     Be well
     Frank McCune
Silicone is known to react poorly with hydrocarbons, so I'd expect more problems and not less. Less is preferable, I'm sure. There might be something better than neoprene, but I'd expect neoprene should work and is probably what OS uses.  y1 Steve
Offline Fred Underwood
« Reply #14 on: June 15, 2020, 04:45:17 PM »
Have you soaked an O ring in your fuel out of the motor/NVA?  What does your fuel do?  But I fly electric, so just asking.
Fred
352575
« Reply #15 on: June 15, 2020, 06:40:56 PM »
     Hi All:
     I do not know what to say after reading the above posts.  My fuel ingredients have been the same for years.  The castor oil, the nitro, and the synthetic oil have been from the same lot.  The alky comes from the same source year after year.  Perhaps the alky has some additional ingredients added.  However, this swelling of the O ring is a new twist.  I have had engine problems in the past, but I ruled out the fuel. It appears that there has been other problems that led to the engines.  I am doing some tests with the O rings in the oils, nitro and alky to determine if on of these are causing the problem.  Will post findings later.
     How can three engines the same all have individual starting, running and mileage discrepancies? For example all ST .60 or OS LA .40 engines.  Each engine is identical to the others. These are 2 cycle engines with about 3 major moving parts. What could go wrong? Lol
     Again thanks for the help.
     Frank McCune
« Reply #16 on: June 15, 2020, 06:59:23 PM »
       No, I am NOT saying that the O-ring expanded when exposed to air. I am saying that is what it is supposed to be sealing against is air leakage. I was looking for a post I thought I made before in this thread but it's not there. I have been working in the maintenance field for 30 some odd years and lots of different applications of O-rings in different environments. Usually what causes an O-ring to swell is something really caustic or some other "hot" chemical like a chemical degreaser or some kind of acid. On some pieces of equipment, it is even desired for the O-ring to swell a bit to help make a complete seal. I have two of these needle valve assemblies from  LA.25's sitting in front of me right now. If everything is working correctly, I don't think the O-ring would ever even SEE fuel. Crank case vacuum should keep fuel flowing AWAY from the area with the O-ring, and the O-ring should just be for ensuring that the threads don't leak air past them. This design didn't work very consistently on earlier OS R/C engines and was often a problem. This design isn't any improvement in my opinion. The fuel comes in the fitting with the barb on it. It turns 90 degrees and goes towards the needle valve and seat, and after it is metered down it turns 90 degrees again and goes to the carb/venturi through the stub that is smooth, no barb. (why do they do that???). I don't like that transition. If the threads are a precise fit, there should be no leakage of air or fuel. If the threads are sloppy, then you get air sucked in and you need some sort of seal up stream, which is the O-ring. The threads on these LA NVAs are pretty coarse compared to what you see elsewhere and pretty short in length. Probably all a matter of keeping production costs down, also known as being cheap to make. I went out to the garage and got two examples of LA.25 plastic back plates with molded on NVAs. One is brand new out of the package.  The other is used, origin unknown, probably came off one I put a metal back plate on and conventional venturi/NVA. The new one, of course, screwed right out. Nice, round O-ring in the square groove that barely offered any resistance. On the used one, guess what!??? It was so stiff I had to use pliers to get it to turn for the first three revolutions or so. When I got it out, the square groove where the O-ring rides is completely filled with swollen O-ring! If I was any good at the photo posting thing I would post a photo , but if some one want to send me a cell phone number or email address I can gladly text a photo or email one. I don't know what fuel this has seen and I'm pretty sure it didn't belong to Frank! This is also NOT the first one I have seen like this. OS has made some pretty good products over the years but in my opinion this NVA is definitely NOT one of them. They didn't work well consistently the first time they came out with them and they still don't. At this point in the discussion, I would venture to say that the O-rings that OS puts in these are pretty crappy. In building and riding vintage dirt bikes, we have to be very careful of what goes through our gas tank and carbs and that means no pump gas with ethanol in it. Neoprene is supposed to be resistant to it but of all the neoprene products I have tried to use I have not found that to be true in either vintage dirt bikes or model airplanes. I would think that methanol would effect things the same way. But my main point is, that the O-ring should not even be SEEING any fuel, if the NVA was designed correctly and built correctly. And I WILL agree that changing to a known commercially made fuel would be a really good test on this. But having said that, there may be some commercially made fuels out there that could do the same thing, depending on what they put in the mix. Testing and time will tell.
« Reply #17 on: June 20, 2020, 10:10:46 AM »
   Just one more addition to this discussion about the o-rings. I have pretty much used SIG fuel almost exclusively since I started going to the SIG contest back in the late 80's and have used everything from Rich's Brew, Excalibur, K&B, Powermaster, Omega, and Fox when I had to or some was made available to me. I have also used SIG fuel syringes almost exclusively over the years to fuel my models. One thing that has always been constant is that the rubber tip at the end of the plunger would deteriorate and make the plunger stick in the body of the syringe. You had to make sure to leave the plunger pulled up a bit from the bottom in between uses, so that when used the next time, you could push it forward to un-stick it, otherwise you could pull the plunger out of the rubber tip. The bottom of the syringe body would eventually turn black. We always made it a point to stock up on a few spare syringes while at the SIG contest because you might go through two or three in a flying season. Then came along guys like Jim Lee and Carl Shoup and some others who produced these fine upgrade plungers for the SIG 5 ounce plungers and what would we do with out them!! But even they had to deal with the same issue when figuring out the exact correct diameter to make the plastic plunger end, how deep to make the groove to hold the O-ring, and what types of O-rings to use. This was all caused by the methanol in the fuel and the only answer to that was fly diesel!! So, in short, I do believe that is what Frank is experiencing with his OS rear needle valve set up. I have accumulated lots of these,( because I'm a parts pack rat and think that they still may be useful for something ) and find lots of them that were used and the O-ring is swollen and mushed flat completely filling up the groove, and I think it is because of the poor design of the needle valve assemble and fuel leaking past the needle and getting to the O-ring. If you use a poor quality O-ring, the rest is history. I have photos of a good, brand new needle compared to a lightly used one if anyone wants me to send it too them. I gotta figure out this photo posting thing.
