Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 04, 2025, 10:12:30 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
St 60 needle valve and head bolts
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: St 60 needle valve and head bolts (Read 2173 times)
dave siegler
2016 supporter
Trade Count:
0
Admiral
sport flier
on:
August 07, 2013, 04:40:04 AM »
I was just given a built up sig magnum and a 80's St 60. The engine is missing a head bolt and a NVA. I have a tiger needle valve, but is seems to be a little too short and I and get the collet on it.
So what nva do I need and what size head bolts?
Logged
Dave Siegler
NE9N extra class
AMA 720731
EAA 1231299 UAS Certificate Number FA39HY9ML7 Member of the Milwaukee Circlemasters. A Gold Leader Club for over 25 years!
http://www.circlemasters.com/
George Mitchell
Trade Count:
0
Ensign
Re: St 60 needle valve and head bolts
Reply #1 on:
August 07, 2013, 07:33:19 AM »
Dave,
PM me your address and I will send you
the head bolts you need. It sounds like
the NVA you have is for a ST 46 it is a
little shorter. Randy Smith will have the
correct NVA or any thing you need for
that engine.
George
Logged
dave siegler
2016 supporter
Trade Count:
0
Admiral
sport flier
Reply #2 on:
August 20, 2013, 04:51:27 AM »
Thanks for the head bolts and the nice letter.
I have a NVA on order. Hopefully will get it together by this weekend.
Just for the record the bolts seem to be standard metric M3 x 5. So I can use socket head bolts.
Logged
Dave Siegler
NE9N extra class
AMA 720731
John Leidle
Guest
Trade Count:
0
Reply #3 on:
August 31, 2013, 12:59:58 AM »
I bought the 3mm bolts for my .60 Tiger but they are the wrong thread. I don't what thread I bought but it's the only one I found & it's incorrect. I guess I'll plan to upgrade to 3.5mm ...or 6-32
Logged
Bootlegger
22 supporter
Trade Count:
0
Admiral
Reply #4 on:
August 31, 2013, 04:13:28 AM »
Fellow's try a 5-40 thread, seems that this one works, of course your mileage may vary..
I have used them in all my Tiger 60's, no problem
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
EddyR
Trade Count:
0
Admiral
Reply #5 on:
August 31, 2013, 06:13:08 AM »
5/40 works fine but I drilled and re-taped to 6/32 any time I had to do a rebuild. Also tap the hole in the exhaust boss if it has one and then a muffler can be mounted there. The original hole threads are to small hold a muffler well. All my ST/46 motors were set up for 6/32
Logged
dave siegler
2016 supporter
Trade Count:
0
Admiral
sport flier
Reply #6 on:
August 31, 2013, 09:22:45 AM »
I don't know I took an existing head bolt and a m3 matched up perfectly
Logged
Dave Siegler
NE9N extra class
AMA 720731
Luiz Ribeiro
Trade Count:
0
Lieutenant
Reply #7 on:
September 01, 2013, 07:18:55 AM »
Dave,
Normally is the 5-40 that fits (7/16" size), so it sounds a little strange that the 3mm fits perfectly. The 5-40 is more nearly the 1/8", with same threads, that is different from 3mm. Take care.
Luiz
Last Edit: September 01, 2013, 09:11:58 PM by Luiz Ribeiro
Logged
EddyR
Trade Count:
0
Admiral
Reply #8 on:
September 02, 2013, 01:03:23 PM »
Your problem with the ST metric bolts has been around since the first ST came down the line. You can match the threads per inch but you are not matching the pitch. I bought a ton of them from ST back in the 1970's. Then there was a place called Nuts and Bolts on US-19 in Clearwater Fl that had socket head correct bolts and I bought all they had, one box of 500. They are long gone so people found that the 5/40 would work just fine and that is what they use. I have never used them myself as I still have a few of the correct bolts. The flat head bolts that came in the motor were very hard to get tightened all the same. Sockets are much better. Be sure your bolt does not bottom out as all holes are not drilled the same depth.Many times there will be one hole under drilled
Logged
dave siegler
2016 supporter
Trade Count:
0
Admiral
sport flier
Reply #9 on:
September 02, 2013, 03:26:47 PM »
I just used a thread gauge and didn't have to guess. Measurement always wins.
The weird part is the prop is 1/4 28 and the rest are m3x .5. So it 1/2 metric.
Guess when this was new you could not go down to the hardware store and get metric fasteners.
Logged
Dave Siegler
NE9N extra class
AMA 720731
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #10 on:
September 02, 2013, 10:10:23 PM »
The early ST 60s were 5-40, the later ones are 3mm bolts
Logged
John Leidle
Guest
Trade Count:
0
Reply #11 on:
September 12, 2013, 09:38:51 AM »
Interesting history , thanks Randy.
Logged
RandySmith
Administrator
Trade Count:
0
Admiral
Reply #12 on:
September 12, 2013, 06:59:21 PM »
Quote from: John Leidle on September 12, 2013, 09:38:51 AM
Hi John
That also goes for the ST40 , 46 35, the early ones were all 5-40 bolts, just as the old 51 56 were
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Jump to:
=> Engine set up tips
